Author Topic: Dellorto twin carb and modified head  (Read 2651 times)
Re: Dellorto twin carb and modified head
« Reply #2 on: December 27, 2010, 11:08:26 AM »
That's nothing, some of the exhausts I have seen...the word art comes to mind with exotic stuff like titanium in them. Watch this space  ;D
The head...old school!
It's a Panda 30 head and the new school is better flow can be achived by modifying a standard head. Italians are now milling-away the head and bolting a smooth casting strait onto the inlet ports.
This smooth casting then takes a Delly or Webber 40. Isn't rocket science in fact they had a youtube vid. on how to do it  :P
Webber and Delly 40's can be tweaked by changing throat size so a good choice [-/ but then the Delly FZD's can also have the throat changed :P I've heard conflicting reports about the 40's but then long conversations with a local tuner who specializes in webbers and Dellys has lead me to believe that with the correct set-up the 40 will outperform the 32 in every way. Flat spots are a sign of a rubbish set-up.
Remember most 40's bought off e bay, one never knows what they came off! Could be that it's set-up for larger or smaller capacity...
Trouble is each step-up in performance seems to have detrimental effects on fuel consumption and one wonders about the sanity of it when figures start to drop to under 20mpg when a big german diesel like my passat will return 50mpg and cruise easily at over 100mph :P :oops: not that I would do that :P
Of interest is single point injection as on smaller VW's etc might need a megasquirt ECU but to my mind, might be useful to keep mpg up [-/
Water cooled should mean you could do even more to a BIS  :P
« Reply #3 on: December 27, 2010, 11:48:52 AM »
I am a bit envious with the amount of after market mods available for aircooled 126s. I have not read or seen any 126 Bis being modified in any way beyond the odd aircleaner upgrade. I like the simple upgrades you can do to an aircooled such as the many Abarth alloy bolt-ons (e.g. rocker cover, sump, exhaust shield), the sport exhausts, upgrade on the carbs, powder coating the exterior of the engine, just to name a few. All these upgrades are original Fiat stuff which only enhances the look and presence of the car. I love my Bis but it is a bit frustrating that there are no upgrades (to my knowledge anyway) apart from the disc brakes, and front suspension upgrade (front independent suspension) and I suppose on a Bis, one can do a port and polish, larger pistons etc. which you can do on any car. But these are very costly upgrades whereas if I had an aircooled, I could gradually purchase upgrades starting of with the Abarth alloy stuff, working myself up. For this reason, I am tempted to buy an aircooled but it is a bit unrealistic to have three 126s.
« Reply #4 on: December 27, 2010, 12:30:07 PM »
 :P It's why I sold my BIS :oops:
Bolt on the bits may be, but god they can add-up to alot of money spent on the car!
At a stab, I'd say there has been £1100 worth of bits bolted-on to my engine.
Head modification etc inside the engine hasn't even started yet!
And to be honest, bolt-on bits dont really make them any quicker :oops:
« Reply #5 on: December 27, 2010, 04:09:47 PM »
(I am tempted to buy an aircooled but it is a bit unrealistic to have three 126s.)
Not really, you could use the aircooled when the Bis breaks down :oops: >:( ;D ;D ;D
DEYAN IYI
« Reply #6 on: December 28, 2010, 01:04:47 AM »
Hi, Amateb8! Amazing things you can do with the Bis's engine as well, but not beautiful...Actually there is not a proper engine room to make it nice, my opinion :oops: But two trunks in return ;D
As you said, the only thing you can do for the outside look is to change the exhaust. There are polish ones, the brothers from Poland will say how to find. Also 500 Giardiniera has something similar, but if it fits. The italian guys maybe have experience in it? The good thing is that the sport exhaust is nice on second place, on first makes the engine breathe and sing.
Other thing is that you already "have" the Panda 30 head [-/ The Bis's one has the same construction. You can put the Panda's manifold to fit Dellorto DRLA 40 or Weber IDF 40.
Then beautiful air cleaner with horns inside... But maybe it needs to mod the floor of the rear trunk. To get more radical there is ... http://www.jenvey.co.uk/ ;) Real thing... :D But....
That's all about the nice look. Your 126 looks great anyway [-/
To make it nice inside you can use also "air cooled" bigger valves, lighter timing chain wheel, lightened  flywheel, oil cooling, modern pistons and con rods, ignition... The bad news is that is hard to reach a sport camshaft, (help again Polish guys!), and can not use out of other models... But after all with reasonable transformations, you'll have not more than 35hp with the standard one. Not much, not cheap, but interesting :)
The Bis gearbox with it's 9x39 pinion&crown is crying out for a 5 speed conversion with short 3 and 4... :oops:
Wake up, Deyan! It's time to go to bed :-X :D
Success! :)
« Last Edit: December 28, 2010, 01:07:58 AM by DEYAN IYI »
