Author Topic: Battery juice !  (Read 2767 times)
126bis1997
Battery juice !
« on: December 17, 2010, 09:39:11 AM »
This is the second time in 3 months. My battery is going thirsty and i would know why because in a particular morning it just has'nt enough power to start engine. So i top it up after ofcourse u bump start and then every thing back to normal. Do you think i need to buy a new battery soon or i may have somtn thats drying up the juice from the battery?? Happy xmas guys and cheers.
Re: Battery juice !
« Reply #1 on: December 17, 2010, 10:00:01 AM »
Would be worth checking out the electricals with a multimeter.
Re: Battery juice !
« Reply #2 on: December 17, 2010, 10:59:23 AM »
I had a cheaper Halfords type battery in mine and somehow it every now and then would go flat.
I wondered whatmit could be so I tried to check the levels in the battery but it was sealed. I had nothing to do so I bought a new one again, this time a Bosch battery which seemed alot better.
But basically it was the car not the battery.
Because I have no RPM gauage of any sort I had set the idling to what I thought sounded sweet, but then one day decided because of the cold weather to up the idling a bit and to my surprise the battery started to behave.
What I think was happening is in my daily trip, while sitting in traffic, the lights etc were draining the battery.
But the BIS has a better altenator so I'd have the battery checked (they do it with a machine) and then with a multimeter check the voltage when the engine is running. I think on a BIS you would expect about 13 Volts or more [-/
Re: Battery juice !
« Reply #3 on: December 17, 2010, 04:31:31 PM »
The fact that it has happened with a 3 month interval suggests that the battery is probably OK & it is just a case that you have been taking more juice out of the battery than the charging system is putting back. Once the modern batteries start to go they can literaly go from fine to dead overnight. Start with the usual suspects , check all battery & earth connections , battery topped up to correct level and the fan belt tension is correct  [-/
Re: Battery juice !
« Reply #4 on: December 17, 2010, 06:54:56 PM »
I had that problem with my Bis as well until I installed a battery isolator. The battery is always fully charged i.e. as you left it after being driven. I recently found that if you leave the gearshift on reverse after you have parked the car and have taken the key out of the ignition, the reverse light remains on. Sometimes, the courtesy light plays up and decides to switch on by itself, although I managed to fix this. But you can imagine, what else is there that is still "live", as it where that can drain the battery. The battery isolator definitely did the trick. I have never had the problem since. Battery isolators also doubles up as an immobiliser as well and is dirt cheap to buy.
126bis1997
Battery juice !
« Reply #5 on: December 17, 2010, 07:56:34 PM »
Well. I in fact have installed an isolator and use it when i park at night but i remember that since i installed an electric fuel pump and wired it so the pump is switched on when ignition is turned on and im figuring it may be that the fuel pump is adding to the draining of the battery. I just checked earth belt and looks fine and the isolator is firmly bolted to the body . So its either the rad fan plus break lights and together with the electric fuel pump that are draining the juice. On an other thaught winter contributes to slow cranking as  the engine is started after a cold night.
Re: Battery juice !
« Reply #6 on: December 17, 2010, 09:34:23 PM »
As mentioned in another thread, car batteries dislike cold weather conditions. I installed my isolator in such a way that nothing works as soon as you switch the thing off. I started my car for the first time with no problems at all since being semi-mothballed when we had the snow. The battery appears to have retained the charge when I last drove the car.
Re: Battery juice !
« Reply #7 on: December 17, 2010, 10:43:15 PM »
Could also be the starter as I found mine was cranking slow because the brushes were worn down alot. [-/
