Author Topic: Instrument Lights Not Working  (Read 1736 times)
triantis
« on: December 05, 2010, 11:30:17 AM »
Hey guys
Back again for more help in the hope to sort out all the problems with my FSM niki (fiat 126)
My electrical problems has been solved. The installation of a new regulator for the alternator solved this. I now have a problem with the lights on my instrument (dash) cluster. None of them work. All fuses in my engine bay (the black plastic box with 8 fuses or so) are in good order. Is there a separate fuse for the interior lights? Is it common for them to stop working? Can someone please give me a step by step guide to sizably out the problem. The Rey of the lighting on the car works. Including parkers, high beams, indicators, etc.
Aaron
Re: Instrument Lights Not Working
« Reply #1 on: December 05, 2010, 12:01:54 PM »
Before you go ripping anything to bits, have you checked that the dimmer knob is not turned all of the way down.  It's that large knob on the right side of the binacle (yours may be missing and just a little shaft sticikng out).  Try rotating this as it dims and brightens the dash lights.
triantis
« Reply #2 on: December 05, 2010, 12:32:55 PM »
There is a small black plastic piece sticking out on the right side of the cluster (missing the dial?) I tried twisting this but nothing...
Aaron
« Reply #3 on: December 06, 2010, 05:05:51 AM »
Hmmm,  then it could be a number of things, blown globes, dodgy dimmer, the wire fallen of etc...
A cheap way out may be to get some of those plug in LEDs you find at K-mart and mount over the glass, though I wouldn't recommend this.
Best bet is to make a donation here and get access to the subscriber's section.  Download one of the manuals from there which should outline the disassembly procedure.  I've yet to successfully disassmble my instrument cluster, I get to that creaking plastic stage (you know the sound it makes just before it breaks) and then I stop.
The globes themselves just twist out of the circuit board with a bayonet type fitting, it's just a matter of getting to it......
triantis
« Reply #4 on: December 06, 2010, 11:12:49 AM »
I have a feeling it's the dimmer switch it doesn't sound or feel healthy when turning it. I will have to operate when I have some free time :)
