Author Topic: vacuum advance  (Read 1903 times)
vacuum advance
« on: December 01, 2010, 09:51:22 PM »
Thought I'd give it a go  ;)
Half BIS half air cooled :P
As the BIS-ista will know the BIS distributor is alot longer than the Air cooled. I cut this one down and will transfer the special riveted spring posts only on the BIS to the Air cooled rotating head.
Amazingly the shaftes are the same diameter and where the dizy goes into the engine is the same diameter [-/
« Last Edit: December 01, 2010, 09:54:06 PM by Darrell »
Re: vacuum advance
« Reply #1 on: December 02, 2010, 01:44:18 PM »
This one looks like an interesting developement that almost slipped under the wire . You must keep us up to speed on how it goes  [-/
smallcox
Re: vacuum advance
« Reply #2 on: December 02, 2010, 04:52:15 PM »
I like the upgrade, but what is your theory on fitting vacum advance to an air cooled?
Re: vacuum advance
« Reply #3 on: December 02, 2010, 10:02:53 PM »
The advance will follow the throttle vacuum and not just the engine revs.
With the present advance it only comes-in when the engine speed increases.
Who knows, they thought it was worthy of the BIS and many other cars so worth a go.
Heck if it doesn't work out I could sell it on e bay to a 500-ista for hundreds :P
