Author Topic: Fiat 126 650cc Aircooled: Alternator Voltage Regulator  (Read 4990 times)
triantis
« on: November 30, 2010, 08:44:06 PM »
Hello
Just following up my alternator issues. I have discovered that my voltage regulator on my FSM Niki (fiat 126 - air-cooled) needs replacing. I have called just about every place in Australia with no luck at all. The regulator is a small steel square unit that mounts to the front of the alternator with two small screws. It has two wires coming from it, one green and one yellow. Does anyone know what the part number is for a Bosch replacement?  I have contacted Bosch and they cannot help me unless I supply a part number. I would like to try getting something here in Australia first before looking to buy overseas. Thanks
Re: Fiat 126 650cc Aircooled: Alternator Voltage Regulator
« Reply #1 on: November 30, 2010, 09:04:14 PM »
Look at the 126fan.sk guys , 9.3 euros plus postage  [-/
Aaron
« Reply #2 on: December 01, 2010, 04:32:59 AM »
Have a chat your local Auto sparkie.  I don't think the regulator is anything special and you may be able to use something generic like a Bosch RE55 regulator (this is what you do to Lada Nivas) as long as it can regulate to about 14 V it should do the trick.  The only downside is that you will have to make a bracket for it and it will look like a bit of a bodge job.  I know the spare engine I have in my garage has had this done to it, though I don't know what the exact Bosh regulator model is - I'll check tonight.
triantis
« Reply #3 on: December 01, 2010, 04:48:03 AM »
Aaron,
I dont mind doing a little bit of a bodge job. As long as it keeps working im happy. A model number off the one you have would make life easier. Also, is there any chance you have a spare drivers side mirror for sale? im missing one lol
Aaron
« Reply #4 on: December 01, 2010, 11:50:55 AM »
Ok lets start with the rear view mirror - I don't have a usable spare - GSXR126 may have or Fiaparts (03)95320794.  Just remember these will have been under the ozzy sun for about 20 years so getting a good one may be difficult.  126fan has them new.
With the regulator, the one on my spare engine is a Bosch RE55 - this is a fairly common one you should be able to get from your local out parts store (I'll exclude supercheap from this but you never know) and will probably cost around $30 or so.  You'll need to make up two extension wires and probably mount this on the side of the engine bay somewhere as I think trying to mount in the original position will clash with the fan belt.
The RE55 has two plugs D+ and DF and according to the wiring diagram in my Haynes manual the D+ wire should be red and the DF wire should be white.  If your Niki is running the original regulator, you'll find both of these wires are coloured yellow just to confuse us.  They stop wrong wiring by using different sized plugs.  Now my Haynes manual has all the pictures in black and white so this makes it difficult to be exact about which wire is which so somebody like Darrell who may have an earlier aircooled may need to veryfy this.  Looking at the photos in the manual, I reckon that the bigger clip wire corresponds to the DF (in my pictures the photo looks white)and the smaller clip wire the D+.  But I recommend strongly checking this with an autosparkie.
Alternatively, just order one from 126fan which has the correct dissimilar sized clips.
Aaron
« Reply #5 on: December 01, 2010, 12:40:05 PM »
I should add that the one on the spare engine looks to be wired wrong, so I'm not using it as a guide.  It's just as likely to be a fried alternator on this one as I've never tried this engine.
« Reply #6 on: December 01, 2010, 09:48:37 PM »
Sorry about the picture quality but it's minus 3 outside :oops:
On the bearing side of the plug next to the green wire is where the wire to the warning light plugs in.
Hope this helps ::)
triantis
« Reply #7 on: December 05, 2010, 11:31:38 AM »
My alternator is now good as new :) just needed a new voltage reg which I sourced from my local auto elec. Thanks everyone
