Author Topic: What a difference a bearing makes!  (Read 1594 times)
tiny126
« on: November 25, 2010, 09:48:12 PM »
Following on from my headlight adventure, I have had to change one of the rear wheel bearings. The car used to be sluggish, but now it accelerates and feels lively (for a 704cc engine). The bearing had collapsed but changing it was a different to any other wheel bearings I have done.
If anyone out there has to do this job, make you sure you have the correct bearing kit. My motor factor stated there was only one bearing kit according to their supplier, but beware there are at least 2 kits available. One kit is 2 taper bearings, oil seal, small oil seal, split pin and cotter nut. The other kit is just 2 taper bearings, 2 oil seals and a spacer tube.
When I stripped the hub off and started to knock out the original bearing, I found out that there are 2 thin circlip type spacers and 1 bearing type spacer. Keep these as the new kit doesn't supply these spacers. It's the same with the cotter nut, no new one is supplied . Luckily I hadn't thrown away these before I opened the box of the new one.
Hopefully, finally, maybe, possibly I will have a bloody MOT tomorrow.
Rob
Re: What a difference a bearing makes!
« Reply #1 on: November 28, 2010, 08:30:36 PM »
Many, many thanks. This is useful information!! Good luck on the MoT!!!!!!!!!!!!!
« Reply #2 on: December 02, 2010, 10:47:41 PM »
Also wheel alignment makes a big diference.
I check mine with a scrub gauge and incredibly the two rear wheels were causing alot of scrub.
I adjusted this and find the car free-wheels better, makes it's top speed easier and uses less fuel [-/
