Author Topic: 126 Disc brake conversion possibility?  (Read 3736 times)
backinblack
« on: November 19, 2010, 10:19:03 PM »
A few years ago i finished off a couple of these buggies from unfinished projects, and remembered today that they did a disc conversion for their earliest model the blitz 1, which was based around a 126.(guilty of hoovering up a good few of the 126's i'll bet) Can anyone tell me if this would be a viable conversion? any thoughts are much appreciated. http://www.blitzworld.co.uk/disc-brake-fiat126-blitz-1-kr2-i44.html
Re: 126 Disc brake conversion possibility?
« Reply #1 on: November 19, 2010, 10:25:02 PM »
See the many many many post on the subject on the forum. Use search facility.
backinblack
« Reply #2 on: November 19, 2010, 10:30:00 PM »
Aye, I had been searching all over, but the cost was huge and these do seem ridiculously cheap [-/
skelz
« Reply #3 on: November 20, 2010, 12:38:16 AM »
mmm looks too good to be true... anybody fitted these ?
« Reply #4 on: November 20, 2010, 07:52:35 AM »
I wonder if either of you guys read below the top line to see what you get for just over £35 plus carriage or did you use the search facility on the forum  ???
skelz
« Reply #5 on: November 20, 2010, 08:46:43 AM »
yep did both still none the wiser !!!  :- :oops:
Eklipze3k
« Reply #6 on: November 20, 2010, 09:06:59 AM »
All that is is just adaptor plates and the relevant bolts. You still need to get calipers + carriers, discs and pads and probably longer flexi hoses too (?). Now to be fair, the calipers+carriers should be easy enough to find as plenty of Cinq/Sei owners upgrade theirs to Punto GT, and it the Cinq/Sei or low spec early Punto ones you need for the conversion (240mm disc), and depending where you look the discs and pads can be had for cheap too.
« Reply #7 on: November 21, 2010, 10:49:29 AM »
I have a complete set from Rusty but not fitted yet but I know it is made up from parts of other fiats........
« Reply #8 on: November 21, 2010, 03:21:51 PM »
Probably said this in one of the original threads...BUT....here we go again..
Got a set of 'Rusty's' , fitted on the car with Seicento calipers and discs.
It was a fairly strait forward job to do and have not looked back.
Rusty sorted braided hoses and bleed nipples for all round, the only thing i needed was 3mm spacers to pull the caliper away from the disc.
I can now watch the terror in arse-creep's faces when they find out that not only can the little car go round corners very fast, and can keep-up with the traffic, but can stop better than most (in the dry)
If it seems too good to be true there are available the 3-500 quid conversions on e bay :P
