Author Topic: Ahh the joys of motoring  (Read 2468 times)
kumar
« on: November 19, 2010, 06:41:31 PM »
Having just picked up a 1981 126 de ville yesterday, I have already stumbled upon the first problem  :(. On my drive back from picking the car up (150 miles) it became impossible to select 1st and 2nd and selecting any other gear feels like stirring marbles with a stick (it wasn't like that to begin with). I have now been told that it is the gear lever bush, and i have even figured out the general location of it, but I can't for the life of me figure out how to get to it. So if anyone can give some advice on how to change it that would be great, I unfortunatley don't have time to wait for a haynes manual to arrive.
Any help would be much appreciated :D
Jeremy
barkingwilhelmina
Re: Ahh the joys of motoring
« Reply #1 on: November 19, 2010, 07:13:05 PM »
Common problem have just done pretty much the same thing. 81 de ville drove home about 100 miles and linkage bush disintegrated...etc, etc.
You need a 10 and a 13mm spanner, some grease, a phillips screwdriver and a socket set will come in handy.
Disconnect the battery.
Diconnect the flexible joint from selector rod to gearbox underneath the car, leave the flexible joint attached to the gearbox as the rod will need to be pushed back into the centre tunnel.
Remove seats and lift carpet to expose the rear inspection hatch ( where the heater switch is) and the front carpet will need lifting to expose the bolts that hold the gearstick in place, there are two of them on the tunnel by the gearstick on the drivers side. If you have the time, remove the carpet as it will make the job easier, I left mine in.
Remove the centre consol tray and rubber gater round the gearstick. This will give you more movement to pull the rod back through.
Mark the possision of the two bolts that hold the gearstick and selector rod in place and then remove them.
Lever the selector rod into the car so the rear end of it is in the centre tunnel. You can now fit the new bush to the bodywork with the help of a screwdriver.
Apply a little grease and push the rod back through.
Align the gearstick and replace the bolts that hold it in place.
Re-connect the flexible linkage to the gearbox, then before replaceing everything test it to see if you can select all of the gears.
Good luck and post some pics if you can.
« Reply #2 on: November 19, 2010, 07:39:16 PM »
 The description above is spot on. I had the same problem now with two of my cars, so last time I replaced the bushes I took some photos. It might help a little bit.
 I ordered my bushes from Ricambio. I find this design a bit better, than the standard ones.
 Good luck with it!!!
« Reply #3 on: November 19, 2010, 07:40:01 PM »
« Reply #4 on: November 19, 2010, 07:41:03 PM »
kumar
« Reply #5 on: November 19, 2010, 08:12:49 PM »
Wonderful, :D
Should be able to make a temporary bush till the actual one arrives, just a little interesting point, i ordered it through an official MODERN fiat/alfa dealer for 99p, its still on the official catalogue! that came as a real surprise.
smallcox
« Reply #6 on: November 19, 2010, 08:52:15 PM »
Hey is that a replacement bush with the brass insert or is that a personnel mod, cause I like it [-/ The grease seems to degrade the bush.
I replaced mine but the new bushes where nylon/plastic, also just for the speed freaks out there, have you noticed how heavy the linkage is as the rod is solid steel bar. I replaced that bar with steel tube to lightern the linkage and have had no side affects. [-/  I quess fiat used solid bar as a cheaper option for machining reasons?
« Reply #7 on: November 20, 2010, 09:28:04 PM »
 Not a personal mod. I ordered them from Ricambio. They not the cheapest for what they are, but did the job great. [-/
