Author Topic: Rear boot lock  (Read 1705 times)
Kent126
    • Facebook Profile
Rear boot lock
« on: November 19, 2010, 12:08:26 PM »
My engine lid shuts, but the lock doesn't work. I can put the key in, but it wont turn. I have has the lock off, and thoroughly cleaned it and given a good coating as best I can with WD40, still no joy.
Is there any way of fixing this little problem, or will I need to replace the whole lock?
The only other thing I was thinking, is that maybe the lock has been replaced but the correct key is missing?
Regards,
Tom
1974 Italian Fiat 126 TA
2008 Fiat Panda 100HP
Re: Rear boot lock
« Reply #1 on: November 19, 2010, 12:14:01 PM »
Take it to a local locksmith, they should be able to either cut a key or make it fit your existing key which is preferable.
Kent126
    • Facebook Profile
Re: Rear boot lock
« Reply #2 on: November 20, 2010, 08:54:13 PM »
blimey, will give the locksmith idea a go. Dont really want to replace it and have a 2nd key, or replace the door locks too just to get a full set.
Tom
Re: Rear boot lock
« Reply #3 on: November 22, 2010, 01:56:07 PM »
You can dismantle the lock assembly and probably do a fix on it. There is an external circlip on the back of the lock barrel assembly. With that removed you can tap out the rectangular pin then remove the key barrel from the housing. Then if you insert the key you will be able to see if any or all of the little detents are protruding and stopping the lock/unlock . If you have only a couple protruding you can just file them off & let the remaining ones do the work  [-/
