Author Topic: Progress...  (Read 8031 times)
Kent126
    • Facebook Profile
Re: Progress...
« Reply #30 on: November 25, 2010, 05:54:08 PM »
Carpets do come out great in the washine machine don't they?  [-/ The bolts to get the front seats out of the sliders are pesky though!
Anyway, hopefully should look and smell better upon re-fitting! :D
Tom
« Last Edit: December 11, 2010, 10:41:43 PM by Kent126 »
1974 Italian Fiat 126 TA
2008 Fiat Panda 100HP
Kent126
    • Facebook Profile
Re: Progress...
« Reply #31 on: November 25, 2010, 05:55:47 PM »
Ok thanks GT master. This problem started happening after I fuelled up!
Will order more consenors!
Tom
Kent126
    • Facebook Profile
Re: Progress...
« Reply #32 on: November 25, 2010, 11:54:19 PM »
Right, it is definitely not the condenser. Just replaced it, after trying a few. This one is definitely working. It has a brand new coil, but im gonna test the coil tomorrow just to satisfy myself that it is working.
It's gotta be fuel related.
Tom
Re: Progress...
« Reply #33 on: November 26, 2010, 08:05:24 AM »
 Try to adjust your points, make sure the gap is correct and adjust the timing. Most of the time I had problem with a 126 it was down to ignition. If this doesn`t cure the problem clean the carb as suggested.
Kent126
    • Facebook Profile
Re: Progress...
« Reply #34 on: November 26, 2010, 09:44:50 AM »
Was looking on the fiat owners club forum, and was told that it could be the carb is drawing in too much air, due to an air leak, or possible gasket failure? Will check this along with the points and timing.
Tom
Kent126
    • Facebook Profile
Re: Progress...
« Reply #35 on: December 06, 2010, 06:26:28 PM »
FOUND THE PROBLEM!!!!
Carb full of poo and silt, has been removed by mobile mechanic and taken away for cleaning and rebuild.
I have been trying to get the fuel tank off today for cleaning out but it appears rather difficult as one of the bolt is knackered, and might need drilling out! hmmmmm
Tom
Kent126
    • Facebook Profile
Re: Progress...
« Reply #36 on: December 11, 2010, 08:06:08 PM »
Well.........carb was re-fitted yesterday after a strip, clean and re-build. Service kit used with gaskets, float, new washer, nut and spacer. That seems to have done the trick along with all the other bits and peices replaced, the old carb parts were knackered on inspection!
Choke cable snapped today, so new one on order. Accelerator still sticking so new cable ordered also (tried lubricating and cleaning linkage but no joy!) so it must be the actual cable itself.
Also didnt manage to get the fuel tank off due to a knackered bolt, so might need to get it back into garage to get them to whip it off and clean it out for me.
Apart from that, it would appear we are back on the road again. Tomorrow im driving from Maidstone to Corringham in Essex, and back again. Should be interesting.....
Tom
Re: Progress...
« Reply #37 on: December 11, 2010, 08:52:06 PM »
Tom , from your picture it looks like you have an online filter fitted plus there is a mesh filter inside the carb . So if the petrol is pumping OK and the online filter looks clear I would not worry. Taking the tank out is not a nice job at the best of times so I would go with a good shot of Redex , full tank of petrol and just keep driving the little beast  [-/ Then drive it some more  :D
You can have fun driving whilst blowing through any c**p at the same time. A bit like those yoghurts that "aid your digestive tract"  ::)
Kent126
    • Facebook Profile
Re: Progress...
« Reply #38 on: December 11, 2010, 10:32:36 PM »
Thanks Rusty, yeah the inline filter is brand new, and the contents look really clear. Also the little mesh filter on the carb has been changed also.
I will fill up tomorrow with some fresh fuel and give him a blast over to Essex and back. Lets hope the girl im picking up appreciates the little beast!  [-/
Tom
Kent126
    • Facebook Profile
Re: Progress...
« Reply #39 on: December 13, 2010, 01:40:52 PM »
 :cry: FFS! Another breakdown!
Started kangarooing again badly so pulled over and got my mate to tow me home!
Back to the drawing board!
Tom
Re: Progress...
« Reply #40 on: December 13, 2010, 01:49:34 PM »
Good luck Tom, you'll get to the bottom of it and then it'll shock you as to how reliable it will be.
I carry a piece of wood so I can push the starter from the back and a spark plug so I can sheck for spark. If I think it's fuel I simply open the drain on the carb to let any rubbish out but kangaroo hopping could be either/or. Sometimes choking the carb with ones hand can pull any dirt in the carb through but quick fix to get home only, if there is still dirt in the carb I suspect that filter you have is an ornament... A bit like my Jack Russell's ears!
My BIS had a horrible habbit of running short of fuel as the fuel pump, even with a new rod and spacer still seemed to stop operating when it got hot. A quick fix was to make the spacer thinner.
I fitted an electric pump and regulator as I have done on my air cooled.
Pete says he went through starters because of the pump so makes sense.
« Last Edit: December 13, 2010, 01:59:50 PM by Darrell »
Re: Progress...
« Reply #41 on: December 13, 2010, 02:54:54 PM »
Tom thumb a lift did ya  ???
Ok sick joke over & that is a real pain and sorry to hear that but do not panic  ::)
Question is fuel or ignition & from what you have said I would put my money on fuel. Did you try the redex as it has a cleaning effect from the tank onwards  ???
Not to be tried by children or people of a nervious inposition but I had a 126 that had been standing for quite a while . The pump was good but could not get the fuel up to the carb. To prove this I found a good sized pickled onion jar which was a good fit in the space where the air filter fits. Punched a hole in the lid & ran a hose down to the inlet on the fuel pump. Petrol pumped through fine and the car was driveable. Proving the tank line was the problem. Points to note, make sure no petrol can spill out, if you do drive the car you have a petrol "tank" that is slightly more robust than an egg & if you do get a back fire then you may shoot a flame at your new petrol tank . All that said it is a way of identfying or eliminating your problem  [-/
