Author Topic: Progress...  (Read 8032 times)
gsxr126
Re: Progress...
« Reply #15 on: November 20, 2010, 10:46:07 PM »
that "heater" must have some bolts loose, bet it will stop shakin if i hold the bumper :D
skelz
Re: Progress...
« Reply #16 on: November 20, 2010, 10:49:50 PM »
Cheers Kent , I seen some for sale that fit on the inside... just cant remember where
Kent126
    • Facebook Profile
Re: Progress...
« Reply #17 on: November 20, 2010, 10:56:39 PM »
Cheers darrell I wont wash the seat covers! lol.
Yeah deffo, sounds like a plan! looking to move back on January 15th to my old place just down Upper Grosvenor Road, so always up for beerage and tinkering sessions! Be nice to have another 126 owner close by!  :D
Tom
1974 Italian Fiat 126 TA
2008 Fiat Panda 100HP
Kent126
    • Facebook Profile
Re: Progress...
« Reply #18 on: November 20, 2010, 11:05:34 PM »
There are currently two 126s whizzing around TW on regular bases.
Just realised, did you see an orange LHD one last year? If so that was probably me when I lived there before after I bought Jan's from him in the summer?
If not then there must be another two in the town!  :D
Tom
Re: Progress...
« Reply #19 on: November 21, 2010, 10:13:59 AM »
 No, I don`t think it was you. I saw your used to be 126 at the Windsor show. It`s still looking good and now has some tasteful mods.
 Beerage sounds good to me [-/
Kent126
    • Facebook Profile
Re: Progress...
« Reply #20 on: November 21, 2010, 08:41:24 PM »
Noooooooooooooo!!!!!!!!!!!! Was totally original factory mint condition!!!!!! :-( but the guy who bought it, now doesn't own it and sold it on again. I tried tracking him down but with no success. Be good to see it again in the flesh though.
Tom
Kent126
    • Facebook Profile
Re: Progress...
« Reply #21 on: November 24, 2010, 09:29:09 PM »
Car died again yesterday! Still think there is some sort of electrical fault relating to the ignition. Now looking at changing the points, belt, checking the belt tension and then see where we go from there, but there cant be much else that needs changing now! :-(
Tom
Re: Progress...
« Reply #22 on: November 24, 2010, 10:06:11 PM »
Tom this is what Fiats are famous for , the electrics. I had a problem with a '67 500 that kept cutting out. Turned out that previous owners had knackered the ignition switch proberbly by having too many keys / weight on the key ring. It forced the back off of the switch.
Then more up to date I had a brand new Bis that kept on cutting out. The car was under warrenty but the garage could not locate the problem (they said) but it was obviously in the wiring loom. I could not locate the problem either so I ran a wire to the input side of the coil back through the car . I left the cover for the interior light off and when driving if the engine cut out I just connected the crocodile clip on the wire to the live feed to the interior light , crazy but it worked  [-/
Re: Progress...
« Reply #23 on: November 24, 2010, 10:29:06 PM »
My BIS used to cut-out and it was because the fuel pump rod was worn. When the engine hets hot the casing expands and stops working the pump.
When it cuts-out check for spark and check for fuel being pumped. That way you get closer to the issue.
Rusty's idea has merit to see if the feed to the ignition is intermittant.
Welcome to the world of Fiats ;) Fix it again tomorrow ;)
Eventually one gets through the problems and they become very reliable but thats why I say 'mint' is a car that will need alot of work as they havnt had all the issues ironed-out  :P
Kent126
    • Facebook Profile
Re: Progress...
« Reply #24 on: November 24, 2010, 10:47:50 PM »
Cheers guys, fuel pump rod brand new and just replaced, so hoping that is one less thing to worry about. I will have a prper fault finding session tomorrow and post my findings!  [-/
Tom
Re: Progress...
« Reply #25 on: November 25, 2010, 09:11:22 AM »
Yes new rod is a good thing to have but still check fuel as odd things happen to fiats like wear in the mechanism in the pump and sometimes poor quality parts.
My advice is always go back to basics fuel and spark.
Kent126
    • Facebook Profile
Re: Progress...
« Reply #26 on: November 25, 2010, 04:23:57 PM »
Carpets out and slowly going through the washing machine.  [-/
Right running issues still, I have checked the points and they open and close fine. Although I didn't see a spark when the engine turns over so could this be the issue? I was told you should see a blue spark?
Engine starts fine, but idles a bit rough and if you apply any throttle then it slowly dies and wants to cut out. It will cut out on full throttle.
I have checked the throttle linakge, and lubricated the cable, linkage and pedal as best as I can.
I think there was a slight misfire, however.
The choke cable is fine, and the choke opens and closes as it should. When you run it with the choke ever so slightly open, it idles better.
There is a new fuel filter, and the fuel looks fairly clean, and the fuel stays sat in the filter when the engine is off, so I am thinking it is not a fuel pump problem? The new fuel rod has also been fitted.
I think the condensor I had replaced the old one with was slightly dodgey, so another new one has been ordered.
I am thinking it could now be more of a carb problem, and perhaps it might need cleaning?
Regards,
Tom
« Last Edit: December 11, 2010, 10:40:22 PM by Kent126 »
Re: Progress...
« Reply #27 on: November 25, 2010, 04:44:18 PM »
If it has a fuel filter installed one would like to assume it isnt the carb but then we are dealing with a 126..
I suspect the condenser first above everything else as I had a look at mine the other day and she does spark a little when running (mine has the two chimney coil with no dizzy cap) so I can see the points operating when the engine is running.
Personally I find one should order 3 condensers every time, as often it's third time lucky
Kent126
    • Facebook Profile
Re: Progress...
« Reply #28 on: November 25, 2010, 04:53:59 PM »
Blimey, are they really that poo? lol
Re: Progress...
« Reply #29 on: November 25, 2010, 05:39:58 PM »
It does sound like there's not enough fuel when the throttle opens (is the engine cold, cause it sounds like it runs fine with the choke on). Best to check out the carb (could be just dirty..)
Condensers really can be that bad. I've seen new ones installed and the car not starting (another new one was needed).
