Author Topic: dellorto dhla 40mm jets?  (Read 1811 times)
rowanshilland
« on: November 13, 2010, 11:33:33 PM »
hi apolageys for eney miss speling as its not mi strong point.
im hoping sumone can tell me witch jets i will need for mi delorto dhla 40mm
to soot mi 650cc 126 i wos also told that the carb wood not have eney efect
without sum head work / porting and polashing been totaly onist im fiting it more for the
look of the carb and inlet manafold but if sum lite head work will make all the difrence i am rebilding the engine
so its not a big problum. it is geting bilt with the same pistons and cilanders as origanal
if that makes the difrence.
bit inbarist as mi ferst post wos about
a 1.2 engin swap but a realaty chek and not woting to
get red of the air coled unit has got mi doun to erth
chers for eney advice.
Re: dellorto dhla 40mm jets?
« Reply #1 on: November 14, 2010, 09:02:27 AM »
Are you Polish in Italy, italian in Poland?
If you are Polish there are hundreds of Polish sites in polish with tons of info regarding jets for carbs. from the language you have used I assume you are not Polish though
I am sure someone will be along to help soon.
Welcome
« Reply #2 on: November 14, 2010, 09:20:47 AM »
takes too long to read that.. :oops:
rowanshilland
« Reply #3 on: November 14, 2010, 08:05:03 PM »
Haha no diceliksick and scotish just problums seting up mi profial
