Author Topic: More Questions!!  (Read 1282 times)
markymarc
More Questions!!
« on: November 11, 2010, 05:13:00 PM »
Sorry guys, i know im a pain and i know this has probably been asked before aswell!!
Can i lower a BIS and were is the best place to get the kit?  Really sorry, i do feel stupid.
Just one more.......found my front and rear screens leak abit, have put fair bit of black silicon all around but found out today still seeping in!! SUGGESTIONS please (sensible only please)
Thanks guys, i promise to get myself sorted one day !!
marc
Re: More Questions!!
« Reply #1 on: November 11, 2010, 06:28:04 PM »
You might have to remove the screens and get new rubber seals ( front and rear windscreens right?), or the pipes that channel the water away may be blocked (at the rear you can see two flat holes from the engine bay in an aircooled, don't know in a BIS, while at the front in the boot there's a plastic pipe both sides that go into the front wheel arches).
« Last Edit: November 11, 2010, 06:30:05 PM by GTMaster »
« Reply #2 on: November 11, 2010, 06:58:38 PM »
Also note that SILICON rots your car!
smallcox
« Reply #3 on: November 11, 2010, 07:17:15 PM »
stop sniffing the silicon fumes, :P
If the rubber seals seem to be intact then a quick fix is to visit your local car factor and ask for some non drying windscreen sealant( remember modern cars are mostly bonded) If the shop does not understand non drying sealant walk away as normal silicon will not seal. Apply this all the way round the rubber both between the seal and bodywork and again between the seal and glass. this is required due to drain hole in the seals that are supposed to allow water to drain away but don't do this, Instead it just speeds up the rusting process so when you remove your windscreen you won't find much metalwork left in the lower corners :oops:
PS homebase sell lowering kits, it's called 25kg bags of sand ;D
markymarc
« Reply #4 on: November 14, 2010, 05:32:19 PM »
Many thanks once again guys
marc
