Author Topic: What else should I replace?  (Read 4008 times)
Kent126
    • Facebook Profile
« on: November 09, 2010, 01:02:51 AM »
After the 242 mile journey home, it is clear that my little fiat has already felt the strain of the long journey after being off the road for 12 years.
I have ordered the following parts which I will be replacing;
Spark Plugs, Rotor Arm, Condensor, Distributor Cap, Ignition Coil, HT Leads, Fuel pump rod and Starter Cable.
Is there anything else that is worth replacing now that is prone to breaking or wearing? Not massively bothered about cost as I would chuck money at the car now and would rather get everything running then have to replace other things later.
I have checked the air filters, and oil. Both are new.
Im upto £74 in parts already (doesnt seem a great deal to be honest). Any advice?
Kind Regards,
Tom
« Last Edit: November 09, 2010, 01:14:44 AM by Kent126 »
1974 Italian Fiat 126 TA
2008 Fiat Panda 100HP
126bis1997
Re; What else should I replace.
« Reply #1 on: November 09, 2010, 06:03:54 AM »
Hi Tom, if I were you I'd check break shoes,wiper blades,and have a few spare bulbs at hand. Cheers and good luck with your Fiat baby.
« Last Edit: November 09, 2010, 10:39:41 AM by 126bis1997 »
Re: What else should I replace?
« Reply #2 on: November 09, 2010, 06:48:20 AM »
Hi Tom , I read your account of your 1st journey , I thought you were very courageous .
I noticed that you did not mention contact breaker points in your list. Always worth having a spare condensor in the car even if you are running a new one. I would also work through a full service shedule probably starting with cleaning out the centrifugal oil filter & changing engine oil. Then if the bodywork is sound I would condider keeping it that way by squirting some Waxoil in the appropriate places & making sure that the drain holes are all clear  [-/
triantis
« Reply #3 on: November 09, 2010, 10:11:31 AM »
Rusty's uncle, what product is waxoil? Is this a simple product sold at an automotive store? Also, what is the best product to spray on areas that already have surface rust? I.e. The bottom of the spare wheel well
« Reply #4 on: November 09, 2010, 12:32:20 PM »
Hi Tom , Kitten asked the same question about Waxoil just over a week ago so I revived my old thead from a couple of years back. Go to the "Mechanical & Problem Solving" section on the forum & you will find it not too far down , last post Nov 1st. Basically you spray the stuff inside doors , sills etc and it will dispell moisture and halt internal corrosion in its tracks. It is not for external application on bodywork as it does not fully harden but it is the most important thing you can apply to your car as it will stop RUST As for the inside of the spare wheel well then you want a corrosion prevention coating that is "over paintable" , that is you clean up the area , spray possibly something like Stonechip then when that has cured it can be spray painted over to match the car. I am sure there are guys on here who will recommend specific products. So while I am at it I would also say that removing any loose material on the underside of the car & inside the wheel arches then applying a good underbody seal is a very good idea  [-/
By writing this it has now reminded me of all those jobs I need to get on with  :oops:
kitten75
« Reply #5 on: November 09, 2010, 05:09:57 PM »
I bought some waxoil at the weekend...now all i have to do is apply it?!
« Reply #6 on: November 09, 2010, 05:43:28 PM »
Remember what the Doctor said "Not to be taken externaly"  :oops:
triantis
« Reply #7 on: November 09, 2010, 09:58:20 PM »
So from what I understand the waxoil is to prevent rust. What should be applied if there is an area which is already showing surface rust? Something like kill rust?
Kent126
    • Facebook Profile
« Reply #8 on: November 09, 2010, 10:04:06 PM »
Thanks guys, some really useful advice there! I will check the break shoes when I get him up on the ramp, and will get some spare bulbs and order a couple more condensors whilst I am at it.
Apparently the car has been serviced, but I will look at the oil filter, and probably change the oil to be on the safe side then.
Bodywork is a tad shabby to be honest, with small rust spots in places and and proper crap re-spray! I intend using the car daily for at least a year and then will garage him next winter and strip him down to sort the bodywork. How much would one of these cars suffer in one year on the road in the elements do you think?
Im also guessing the condensor is a common problem then, as I have found out already?
and Rusty yeh, I thought 'bugger it' im gonna go for it and drive the whole 242 miles! Courageous? Maybe. Stupid? Most definately! But you know what? The amount of looks, beeps, thumbs up and photo's being taken of me was well worth it! :-)
I am very much looking forward to getting her running for daily use!
Thanks for the advice guys, looks like this forum is gonna be an essential daily part of my motoring life! lol
Tom
gsxr126
« Reply #9 on: November 10, 2010, 12:25:34 AM »
Dont use kill rust on your car :o most automotive paints dont take too well to it. Use a rust converter then primer then body colour paint.
Feel sorry for u guys in the UK having to go to such extremes to stop/prevent rust :( Would anyone know how much weight, on average, waxoiling a 126 would add ??? just curious.....
Funkin Go-nut
« Reply #10 on: November 10, 2010, 07:51:29 AM »
Dinitrol do a great range of rust prevention and cure products.
Their cure rust converts brown rust and coats with an epoxy coating to seal it.
They also do spray waxes and under sealants as well, but it not cheap...
Best thing to do with rust is to grind it away, treat the bare steel, fill then prime and paint...
Which isn't as easy as it sounds, plus it always seems to go deeper and spread further than you think  >:(
« Reply #11 on: November 10, 2010, 10:54:28 PM »
Definitely get the car waxoiled and undersealed as well. I got mine done by a local garage.
« Reply #12 on: November 11, 2010, 12:55:49 PM »
Re condensers , still some on eBay for 99p + postage  :D
As for waxoil I think that you could do pretty thorough job on a 126 and only add way less than 1 kg to the weight of your car. Firstly you only need a thin coat as it is for internal sections , you can thin it & the white spirit element releases slowly to leave the wax & oil coating. If you over do it then the excess will just run out of the drain holes in sills , doors etc. especially on a hot day. If you make your own you can even colour code it to your car  [-/
« Reply #13 on: November 11, 2010, 03:00:31 PM »
I want to make some red waxoil, so it can look like it's bleeding in the hot weather  :P
Kent126
    • Facebook Profile
« Reply #14 on: November 13, 2010, 03:01:41 AM »
Ok, waxoil and undersealing now on the list. Just ordered a new starter motor too! (Not cheap!)
Tom
