Author Topic: My Incredible Adventure  (Read 1458 times)
Kent126
    • Facebook Profile
« on: November 06, 2010, 10:45:08 PM »
Well.......
Went to manchester to pick up the car, and the intention was to drive it 242 miles to maidstone. Well we made it (just!)
Kept stopping for petrol, and asking people to give me bump starts as he decided he wasnt going to start on his own, and then going down the M6 he cut out, lost all power and ground to a halt. RAC called, and 1 1/2 hours later I was back on the road.
The RAC replaced the small condensor to get me going, but apparently it will need replacing as it isnt the right one for the car. Stopped, again. Wouldnt start. Bump start once more, and on my way.
Last 30 miles very hairy, as car was kangarooing and I managed to limp him home.
Turned off the engine at home, then out of curiosity re-started it to which it fired up, but the starter cable snapped.
All in all a bloody long day, and quite an adventure.
S
1974 Italian Fiat 126 TA
2008 Fiat Panda 100HP
Kent126
    • Facebook Profile
(also help needed....)
« Reply #1 on: November 06, 2010, 10:49:53 PM »
So after all that I have some questions which im hoping someone might be able to answer.... :-)
Being not that mechanically minded, even though the starter cable has snapped, can I start the engine from the rear for the time being until it is replaced?
With only basic tools (as the rest of mine are at my parents) is it relatively easy to replace the starter cable?
Does anyone know what the correct condensor is that I need to put on the car?
Is there anything else I can do to make her run a little better? Ran her on superunleaded on the way down. Battery is new and working, coil is working (according to the RAC man), spark plugs are ok, and distributor cap is also fine.
Battery light flickers on when driving at top speed, and the RAC man said the engine had a weak spark. Any ideas greatfully received! :-)
Tom
Re: My Incredible Adventure
« Reply #2 on: November 06, 2010, 11:18:29 PM »
Starter cable is relatively strait forward to replace, order the plastic clip for the lever with the cable as it will probably break on removing the old one ( they aways do )
Starter cable available and clip through Chet at Ricambifiat500
They'll also have the correct condersor.
Weak spark could be the coil, they'll have one too.
Personally I have had bad experience with the electronic ignition system they sell and it seems I am not alone.
You can move the starter lever with a wooden pole to start the car when the cable goes. Use wood as the lever can become alive.
Did the timing get re-set with a timing light? A timing light is an absolute must as too far advanced will result in overheating.
Have you checked the points gap and are they old points?
I'd give it a full service so as you know where you are starting from.
As a matter of maintenance I'd replace the rod that drives the fuel pump as they wear down and make the pump less effective....kangaroo hopping is often a symtom of that. Normally worse when engine is warm.
This is why I believe the more they are used the better, as one gets all these silly little problems out of the way. Then hopefully it is just maintenance unless you start worshiping the god of speed....
Full manual on the site by the way [-/
Kent126
    • Facebook Profile
« Reply #3 on: November 06, 2010, 11:49:17 PM »
Thanks, gaps were checked by the nice RAC man and he said he closed them up a tad.
Have ordered condensor and cable from where you said. Not sure about the timing to be honest, but it has apprently been given a full service prior to me picking it up.
I shall also find a decent length of wood. Do I need to poke this down the rear of the engine.
Will also look into replacing the fuel pump rod also! :-)
Like you say, once all little niggles are sorted I will be using it daily and it should be a nice little runner' Just a shame about the crap re-spray! :-( (that is a job for next summer!)
Tom
Kent126
    • Facebook Profile
« Reply #4 on: November 06, 2010, 11:51:17 PM »
some pics for your amusment! :-)
Tom
