Author Topic: Petrol cap dilemma...  (Read 3349 times)
kitten75
« on: November 06, 2010, 05:45:12 PM »
Right, key snapped off in petrol cap this evening...oops.  Any ideas?!
Mhairi
Re: Petrol cap dilemma...
« Reply #1 on: November 06, 2010, 06:05:59 PM »
If the cap is in the unlocked position  then I would say do not panic as it will be easy to replace. If it is locked then find a good set of long nose pliers to trurn or remove the base of the key  [-/
kitten75
« Reply #2 on: November 06, 2010, 06:08:18 PM »
Thanks Rusty...think it may be in the unlocked position but will check tomorrow in the daylight.  This might be something I could fix myself, how exciting!
« Reply #3 on: November 06, 2010, 06:24:11 PM »
 :D Oh you know how to have fun !
Not sure about round your way but these days you do not get too many of the guys coming round to syphon petrol from your car as most cars have some sort of prevention device. Sure it will be an easy fix  [-/
« Reply #4 on: November 06, 2010, 07:47:11 PM »
MIght have a spare cap and key floating about  [-/
kitten75
« Reply #5 on: November 06, 2010, 08:07:19 PM »
Thanks Darrell, very kind. I've sent you a PM.
« Reply #6 on: November 06, 2010, 08:30:16 PM »
*gone digging in the shed*
« Reply #7 on: November 06, 2010, 08:54:40 PM »
Just to confirm, does the Cinq/seicento cap fit the BIS?
« Reply #8 on: November 06, 2010, 10:26:06 PM »
i thought i had posted but i shall try again...
if you have the right type of cap then you might be able to try this, some caps have a plastic cover that if you prise off by getting a screwdriver under the lip then you can get a pair of multigrips and undo the metal part of the cap. just by taking the cover off disables the locking part of the cap as it is only the outer that spins that stops you from undoing the cap remove it and you can grip. i found this out after buying a car up north and finding out at the petrol station (with no fuel left in the car) that i had no key! hope it is the same type of cap on yours!
kitten75
« Reply #9 on: November 06, 2010, 10:34:25 PM »
Thanks for that - i will try that also.  Was on way out and stopped to get petrol when key snapped, stood for about a minute wondering what i should, then realised I couldn't do anything!  Luckily, I had enough petrol to get me home!!
M
gsxr126
« Reply #10 on: November 06, 2010, 11:03:19 PM »
I did that too (crack the cover) as the pins thingys inside were all stuffed. I didnt bother fixing it and used a Fiat badge to cover the small hole thats left from the barrel. I cant lock it now but not too worried. Still have a safeguard from people stealing petrol though. [-/
kitten75
« Reply #11 on: November 07, 2010, 05:07:26 PM »
Unfortunately I don't have such a deterrent for fuel thiefs!  I did however phone the nice people at RAC and after moving the car 0.25 of a mile away (don't have membership for home) they came out, stuck a huge screw driver in it and managed to get the cap off.  Bit of greasing later and the cap works with the little stub of key left!  I will still need a new one but for now problem solved...
Thanks for the tip Darrell - like you say good to get money's worth out of these breakdown folk!
M
« Reply #12 on: November 07, 2010, 09:33:18 PM »
Looking for the cap today but then a mate decided we needed to take the bikes out as it'll probably be our last chance to ride without being frozen solid or wet or both.
Think you have it bad with a 126? The salt damage over the 3 years on my sportbike has resulted in a huge rust hole in the exhaust in a spot right in the middle of where the four pipes join-up. Looking at it, it'll probably be around £200 to put right with my own labour :(
Sure I hung on to that cap... I'll find it tomorrow :oops:
gsxr126
« Reply #13 on: November 07, 2010, 10:24:58 PM »
If the key still works a good locksmith should be able to cut u a new one [-/
kitten75
« Reply #14 on: November 08, 2010, 03:41:09 PM »
cheers...majority of key is still stuck in the lock but i can get round it by using what little is left on the key fob...def need a new one as i don't fancy fannying about with it at petrol stations...(excuse the expression!).
Re rust in exhausts, i'm terrified about the fiat as the weather is turning - am still debating putting him away for the winter?
m
