I would have thought one of the BIS faithful would have replied to your post by now, however I'll jump in as you seem desparate.
Air-cooler to the rescue...
I had a BIS and the exhaust is fairly simple.
Two pipes emerge from the head to a silencer box then out the back in a single exhaust pipe.
Air is sucked past the one pipe to heat the air that enters the carb. during the cold weather.
This air comes from an arrangement on the one exhaust downpipe , and is then piped to the airbox. On the airbox there will be a switch to change from a summer to a winter setting.
Purchasing a new BIS silencer should give you the arrangement fitted to the exhaust.
Be cautious when unbolting and fitting a new exhaust, use penetrating oil and be sure not to leave any bolts out of the supports adn it will simply rattle loose if any bolts are left out and be sure to re-instal all locking washers etc.
Go to the top of the page and click 'Home' and then look in the subscribers section on the left I think it is.
Hope this link works:
http://club126uk.co.uk/index.php?pid=10
