Fiat 126 Chat
oil cap
Pages: [
Topic: oil cap (Read 1350 times)
massa
Member
oil cap
on:
October 31, 2010, 09:12:29 AM »
anyone know if the bis uses the same oil filler cap as the air cooled ie with the spring and the little valve on the end my bis did not have that type on but have a new one with spring and valve on ok to use ? thanks lads and lasses dave
Administrator
Re: oil cap
Reply #1 on:
October 31, 2010, 03:41:32 PM »
Hi Dave the oil cap are the same on the air cooled and Bis
The disc is important without it the induction system starts to pull oil from the engine at high revs and soaks the plugs Which stop firing as i found out on the M1 Motorway, Limping off on 1 cylinder Replaced the plugs at the side of the road and it got me home Replaced with a new air cooled cap and everything is hunkydory now [-/
Pete.
il cavallo piccolo
massa
Member
Re: oil cap
Reply #2 on:
October 31, 2010, 07:15:07 PM »
thanks pete new one fitted are they all sods to start when cold just set points timed using strobe at 10 btdc see what its like tommorow thanks again pete
Pages: [
Fiat 126 Chat
oil cap
