Author Topic: Engine tempreatures  (Read 2205 times)
Engine tempreatures
« on: October 27, 2010, 11:14:55 AM »
I bought a capillary type temperature gauge and fitted it into my large capacity alloy sump.
It shows the maximum oil temperature I can achieve so far of about 70 degress, obviously not as hot as summer I guess.
This didnt seem too bad but i still smell from time to time burning oil in the heater airflow thus bought an infared sensor, the type one simply points and it uses clever lasers or whatever and the alloy rocker cover sits at 110 degrees. I pointed it at the exhaust to find a reading of 350 degrees C!!!
Dunno if that is a bit too hot but it brings me to the thoughts of exhaust wrap we discussed some time back, surely this heat needs to be radiated as soon as possible or the pipe would just get hotter and hotter and being connected to the head, I figure thats why i smell burning oil.
I think the burning oil is coming from the crankcase breather somehow getting into the cooling system..
My thoughts to ease this would be to increase the ability of the exhaust to loose heat near the head thus some sort of heatsink, don't think I'll ever get the smell to disappear completely with heatsinks, have to re-position the breather :P
Interesting gadget these laser temp sensors, been setting boiler and all sorts :oops:
Re: Engine tempreatures
« Reply #1 on: October 27, 2010, 03:17:18 PM »
give a boy a toy....
« Reply #2 on: October 27, 2010, 09:05:42 PM »
He who dies with the most toys wins  :P
smallcox
« Reply #3 on: October 30, 2010, 09:18:23 PM »
Darrell don't worry about your exhaust pipe conducting heat to your head this is normal for the exhaust to be hot . In fact you need the exhaust as hot as you can get it to ade good gas extraction and increase performance and mpg.
You wont beleive me if i tell you mine glows cheery red in the dark and the head still survives for another day [-/
« Reply #4 on: October 30, 2010, 11:35:57 PM »
Thanks for that Smallcox, I've had more luck with getting rid of the oil burn smell in the car, I tried Bis13's trick of plumbers tape round the dipstick to hold it in as it has been leaking oil out of the dipstick.
What I did was to wrap the plumber's tape around the dipstick wire bit to make it thicker, put the rubber bit back in place and it is alot better snug fit now [-/ no oil leak and amazingly no oil smell, I guess gasses were escaping into the heater tinware.
Breather mod tomorrow, an extra one from the crankcase, from where my fuel pump used to live, just need to be sure it doesn't end-up to be a way to loose oil :oops:
Exhaust seems to stay pretty constant at 350 degrees C and rocker cover between 80 and 110 degrees.
Sump oil still about the same max 70 but crankcase can reach 85.
Soon I will try the temperatures after a bit of a motorway run  [-/ when I'm sure the therostat is behaving.
Thermostat is back in place but not convinced it opens properly at the recomended 80 degrees C, tried both types available, not had any luck with the one that looks like an accordian, the other type seems to open a bit at 80, but not sure it opens the whole way...hmm will remove and test properly tomorrow [-/
« Reply #5 on: October 31, 2010, 08:37:14 PM »
as long as it opens, the old bellows type have more travel but are weaker than the new type which however do not open as much but i think that if the thing opens then that at least lets the hot air out and when closed does the job it should do after all it is there to help the cold engine on cold mornings.
