Author Topic: Electrical problem  (Read 1591 times)
Alex
Electrical problem
« on: October 25, 2010, 09:56:05 AM »
Hello people,
got a great question this time,
after the problems i had with the distributor, i managed to get it all fixed together nicely, but now the spark plugs won't fire, i have changed them but still no spark,
so i went through a process of elimination to see what is wrong, first i checked power to distributor, there was a spark when touching points with screwdriver.
then i checked wire from coil to distributor, there was a spark.
so now i'm confused, i have power going into distributor, and the coil is ok, so why are the sparkplugs not sparking?
i have not changed the condensor yet or HT leads, also would a voltometer read the elecrical charge coming down the HT leads.
or does anyone think it could be anything else i have not checked?
also by mistake i touched the points when the ignition was switched on, was a massive bang noise, the starter did turn over afterwards, but is it possible i could of done more damage by that?
Alex
Re: Electrical problem
« Reply #1 on: October 25, 2010, 10:29:31 AM »
Lucky it wasnt in gear when the bang occured, reverse would have been a problem :oops:
No damage should have occured I guess
I think your points need cleaning.
If you take the lead off from the coil and fiddle with the points and you get a spark from this lead it means the wiring is all in place and correct.
Rest this lead somewhere close to a metal casing, dont hold it, it's high voltage!
Don't do this test should you smell petrol or see petrol leaking. Wear insulating gloves boots full welding apron, overalls, safety glasses ear defenders and ensure car is in neutral, have a fire extinguisher, and fire blanket close to hand and find someone to watch you with a mobile phone and access to all relevant emergency numbers, a first aid kit, person should be a qualified first aider........this should cover any liability :oops:
Now crank it and see if you get a spark, if not, clean or replace points (rub some fine grade sandpaper between the points contacts)
Crank again and see if you now have spark
Maybe have a mechanic look at it
smallcox
« Reply #2 on: October 25, 2010, 01:25:54 PM »
Hi Alex,
Sound's like you have had your fair share off ignition problems with this one reading through the forum.
did you resolve the missing screws, what about lumpy running when the throttle is pressed?
From what you say you have a volt meter, does this read ohms/resistance if so some quick checks should help you on your merry way.
with igniton off pull the wire off the twin coil that goes to the distributor now set the meter to ohms and place 1 lead to bodywork and the other to this wire, now turn engine by hand and look for a reading off total open circiut to a low resistance, ie close circiut as points are operating. rectify if this is not so.
Remove the HT leads and place your ohm meter at either end and check the resistance of each lead. Anything between 6000-20000 ohms is good but higher than this change them as they are breaking down.
Sparkplugs checked for damage and gapped.
9-12v supply to coil can be easyly checked with your volt meter.
other than the coil resistance to be checked the only part that is difficult to fault is the condensor so will requires changing if still no joy :oops:
Good luck
