Author Topic: Rear Valance  (Read 1854 times)
Alex
Rear Valance
« on: October 22, 2010, 12:19:59 PM »
Is it possible to remove the rear panel/valance without having to jack up the engine?
cheers
Alex
Re: Rear Valance
« Reply #1 on: October 22, 2010, 12:22:34 PM »
If you dont you'll end-up with an engine hanging on whatever is shortest and connected to the engine and you'll probably end-up trashing your gearbox mounts.
It's not so much of a case of jacking it up as providing support although a small about of jacking is required to relieve the tension on the mounting spring.
You'd be nuts to try not using a jack..
Alex
Re: Rear Valance
« Reply #2 on: October 22, 2010, 01:04:23 PM »
Cheers Darrell
was not sure, but will jack up now.
cheers
Alex
Re: Rear Valance
« Reply #3 on: October 22, 2010, 04:07:18 PM »
I have often used a short piece of nylon cord tied to an approriate part of the engine, the lifting lug if you have one fitted then run the cord though the stay that the engine cover catch locks onto. Give it a good pull to lift the engine slightly , secure it then you soud be able to remove the rear panel & bumper etc  [-/
Re: Rear Valance
« Reply #4 on: October 23, 2010, 01:04:32 PM »
i have the special tool for doing this job. i shall take a photo of it and deconstruct it so if you wish you can then fabricate one yourselves.
neil 126
Re: Rear Valance
« Reply #5 on: November 06, 2010, 06:20:54 PM »
10mm threaded bar can be used through a piece of timber and fitted into the hole in the engine casting that the bracket that all the pipes are held in on top of the engine.
Remove the hoses from the braket, remove the bracket and the stud from the engine, thread the threaded bar through the timber with a washer and nut on the top side of the timber, screw the bar into the engine and do up the nut until you start to raise the engine.
You will need to cut the timber so that it bears on the left and right side of the engine bay.
This is a good method if you think you may have the rear valance off  the car for any length of time and it means you can use the jack for other jobs.
Tried and tested.
learnt it the hard way
