Author Topic: Advice please.  (Read 1927 times)
126bis1997
Advice please.
« on: October 21, 2010, 07:18:47 PM »
Hello again.
I just took out engine and gearbox from a bis that I bought for parts. Engine is done . Its all bolts and nuts to put on shelves for future use if needed. But the gearbox is still in one piece and shafts are still attached. Question is; should I take off shafts?? Or even should I open gearbox and disassemble it or leave it as it is?? As storage space is no problem in that case. Thank you. PETER.
Re: Advice please.
« Reply #1 on: October 21, 2010, 07:36:16 PM »
Hi Peter,
If it were me I would power wash it off and keep it in one piece then you are assured that you won't loose any of the smaller components, plus its easier to remember where all the parts go when you need to replace a component if you have just taken it apart ;D
Re: Advice please.
« Reply #2 on: October 21, 2010, 10:21:32 PM »
Pete's right I recon but I'd be tempted to take the cover off the top of the gearbox to see what condition the 1st/reverse gears are in.
They are right on top and usually have a but of the one edge of the gear graunched. If it has missing teeth or more than say 2-3mm of the gear chewed away it might be worth getting a repair kit from the likes or ricambifiat500
