Poll
Hi, i am new to this forum with my very early 1973 Fiat 126.
message
0 (0%)
telephone
0 (0%)
Total Members Voted: 0
Author Topic: 1973 Fiat 126 problematic manual gearbox  (Read 2741 times)
jemima
« on: October 19, 2010, 08:44:49 PM »
I have just finished restoring this manual car (after it being off road for a few years, with previous owner) and the problem i have, is that engaging 3rd & 4th gears when moving is impossible, and all it does is crunch.
When it is parked up, on tick over, it is possible to engage gear.
Can anybody give me any ideas on what the problem is and how to resolve it.
Thanks, in anticipation,
Terry (stoke)  ???  :-
Re: 1973 Fiat 126 problematic manual gearbox
« Reply #1 on: October 19, 2010, 09:07:23 PM »
Could it be that the clutch isn't set properly (that it's not lifting out enough)?
jemima
« Reply #2 on: October 19, 2010, 09:17:10 PM »
 thankyou, do you mean the cable needs ajusting as this is my first 126 ??
« Reply #3 on: October 19, 2010, 09:20:51 PM »
OK , all been said here before but a refresher lesson  [-/
Assuming that gearbox mounts and flexible coupling are Ok :
If you have trouble engaging 1st & 3rd or 2nd & 4th then the gear lever box can be adjusted by the two bolts that mount it to the tunnel.
Trouble engaging 3rd & 4th , assuming that the gearbox is OK , is almost certainly the bush that guides the connector rod through the back of the gear lever box.
When that little plastic bush goes your gear change is screwed  :oops:
« Reply #4 on: October 19, 2010, 09:21:41 PM »
Hi Terry.
The obvious things to check are the the LH/RH gearbox mounts, The gear linkage coupler, and the gear lever mounting plate position, As GT said make sure the clutch is operating properly, Normally its usually worn gearbox mounts that are US that allow the engine to move so its difficult to select the gears [-/
« Reply #5 on: October 19, 2010, 09:24:50 PM »
Yes you can also try adjusting the cable. The pedal has to travel about 20-30 mm (thats about 2-3mm at the release bearing) before you can feel the point where the pedal goes in and 'lifts out'. At the end of the cable at the gearbox is an M6 nut and a large nut (a bit cone shaped) with which you can adjust the cable (the M6 nut is there to secure the larger nut).
