Author Topic: What a Nightmare  (Read 3985 times)
Alex
What a Nightmare
« on: October 16, 2010, 01:25:56 PM »
Big drama yesterday morning, after driving the car to the train station, the engine cut out and would not fire,
after closer inspection today, two screws have worked themselves loose from the distributor cap, so not surprised the engine wont fire.
does anybody know where i could get some replacement screws from?
also when i was inspecting the engine i noticed a load of oil has been thrown from the engine on the left side.
it has covered the fan and alternator as well as the engine cover lid, anybody had a similar thing happen, do you think it could be the gasket on the oil sump? i have checked the dipstick and there is no emulsification of oil and water.
any help will be very much appreciated.
Alex
Re: What a Nightmare
« Reply #1 on: October 16, 2010, 04:26:18 PM »
The screws are standard metric threaded screw so should be able to get some from a local bolt supplier. If not speak to Chet at Ricambifiat500, google for the number.
The oil could be from the fuel pump, there is a thick bako spacer that often splits.
I'd fire it up and have a good ferret about, obviously when you get your screws. Clean the engine first so the oil leak is obvious. I've just done this exercise to find the oil leak on mine is the dipstick :o
« Reply #2 on: October 16, 2010, 04:30:03 PM »
Alex, Aircooled or Bis? I'm also in Essex and have a few spares if Aircooled.
Alex
« Reply #3 on: October 18, 2010, 08:51:20 AM »
will call that Chet guy, i did call the guy from Ricambio but not had an answer yet,
i'll take the last remainig screw out and take it to a nut and bolt shop.
Hi Dajwid, its a BIS unfortunately.
Hi Darrell interesting it was the dipstick, have you resolved that problem? just in case the same thing is happening to mine.
also if it is the oil sump gasket, is it a relatively easy job to do with the engine still in the car?
cheers for the advice
Alex
« Reply #4 on: October 18, 2010, 09:12:12 AM »
Hi Alex, daj's bit may be ok as the BIS was a simple step-up from the air cooled where they put a vacuum advance on it, it is just a bit bigger.
My dipstick issue hasn't been resolved. I have a feeling due to the age of my engine and how much mileage I've done, it's a bit knackered because it produces alot of sump pressure.
Ad job on a 126 is nowhere near as bad as any modern car. I'd advise making a donation which will give you access to the workshop manuals online here on this site. They simply plan the job and take your time.
Most of the problems I have encountered are because I was in a hurry to get the job done. :oops:
Alex
« Reply #5 on: October 18, 2010, 09:43:33 AM »
Hi Darrell
cheers for the advice, hopefully Dajwid will have the screws,
i did buy the workshop manual from Pete126, it has been a lifesaver with some of the jobs i've done, does the donation give you access to other guides then?
i'm hoping the oil leak is relatively easy to sort out, i'll also change the oil, don't think its ever been changed,
will keep you posted.
Alex
gsxr126
« Reply #6 on: October 18, 2010, 09:50:50 AM »
I found that my sump bolts rattle loose occasionally. When it starts leaking a find i have to nip these up. I have an engine with a bit of blowby and it was leaking from the dipstik. I used a small rubber cap around the round metal locator thingy on the dipstik and this gave it some seating pressure and stopped the leaking-from there anyway
« Reply #7 on: October 18, 2010, 10:33:34 AM »
The full manual is on the site, it's just a donation that gets you in.
I am worried that by simply sealing-up the dipstick, I'm going to end up with a leak somewhere else...
So happy to accept the leak for now till I can get a crankcase breather fitted.
I think this is an advantage of the BIS is that the breather is directly off the crankcase
« Reply #8 on: October 18, 2010, 02:09:16 PM »
cant you use the old fuel pump push rod opening for this and make something up? i know there is a bolt on jobbie you can buy from somewhere (nanni i think).
« Reply #9 on: October 18, 2010, 02:13:49 PM »
Yeah I made-up a plate for where my fuel pump used to be.
It's just a case of drilling and tapping and finding a hose fitting and should be job done, just need to get off my.... :oops:
« Reply #10 on: October 18, 2010, 04:32:23 PM »
Bit of a Bis thread hijack but bearing in mind that many of our older engines have been used & abused the steel sump on the aircooled is worth a good inspection if you get it off. Apart from the fact that the air cooling channels on the base get clogged & stoved in so you loose your oil cooling potential. Also as the sump gasket is quite thick along with the fact that it is easy to get a socket on the sump bolts it is easy to overtighten and distort the sump gasket face local to the bolt holes. Net result is that the gasket may not seal no matter how tight the bolts. I have just tapped one back into shape ready for refitting and I will use large washers to spread the load at the bolt holes  [-/
Alex
« Reply #11 on: October 18, 2010, 04:40:40 PM »
Going back to the Distributor problem, as all the screws worked themselves loose so did the wires inside.
i dont suppose anyone has a colour picture of the internal workings of a Zelmot distributor?
I have a black & white picture from the workshop manual, but just want to be 100% with it.
still trying to find some screws! as its the only car in the household now, i don't fancy the 3 mile walk to the industrial estate.
on a good note though, i spoke to Webcon today and had a good long chat to John, that man knows his Carbs :o :o :o and he very kindly agreed to send over an exploded diagram of a Weber 30 DGF 3/150, he also gave me some advice on what to look for when cleaning up said carb.
Cheers for the advice so far its been invaluable
Alex
« Reply #12 on: October 20, 2010, 08:42:50 AM »
Hello Again,
still having no luck finding any of those screws, does anybody know what thread size and length they are?
one of the screws holds the vacum advance onto the distributor, the other holds the condenser in place.
Please help!
tiny126
« Reply #13 on: November 05, 2010, 04:54:09 PM »
Hi Alex
I will have a look tomorrow for you. I have two engines so I may have the two different distributers. PM me with your mobile number and I will send you a picture msg if I have a zelmont dizzie. I will also send you the thread size and length.
Rob:)
« Reply #14 on: November 05, 2010, 08:16:14 PM »
As a temporary solution you could try a couple of nuts and bolts that go through the holes in the distributor with anti rattle washers or nylock nuts ;D
