Author Topic: Oil filter advice  (Read 2216 times)
Aaron
Oil filter advice
« on: September 29, 2010, 05:52:08 AM »
Guys,
How important is the oil thrower in the oil filter?  The reason I ask is that I know my engine does not have one fitted.  So far I haven't had any signs of low oil pressure or dirty oil.  The oil pressure light goes out within 0.5 secs of the car starting.
Looking at the diagram in the Haynes manual, the flow through the filter is depicted as going from outside of the crankshaft to the outer edge of the pulley then flows inward into the hollow crankshaft.  I would expect this to be operating in a flooded condition and as such this thrower to me looks more like a flow restictor more than anything if the depicted flow is correct.  If this is such I'm guessing this ensures some oil flow to the cam shaft rather than total flow to the crankshaft.
Considering that the engines are doing between 2500 - 4500 rpm most of the time while driving, I wouldn't expect the centrifugal force to be high (in relative terms).  Should I be thinking about finding one to re-install?  The pic below is from the oil filter cleaning guide on here showing the thrower in question.
gsxr126
Re: Oil filter advice
« Reply #1 on: September 29, 2010, 10:47:34 AM »
I dont think they operate flooded. Check out the pic in Rusty's oil filter thread and have a look at the muck before he cleaned it. Maybe they flood at the crankshaft opening.
« Reply #2 on: September 30, 2010, 06:58:59 PM »
I guess it was put in there for a reason so it is important to have one (probably helps the oil to be thrown in the correct direction towards the lid). Though if you don't have problems with oil pressure  then fit one when you have to take the crankshaft pulley off for some reason. I damaged mine a bit when straightening out the washer under the pulley bolt but i guess it won't effect the oil flow.
Aaron
« Reply #3 on: October 14, 2010, 05:23:27 AM »
Sorry to dig up a bit of an old post but,
I took the cover off the filter on a spare engine I have today.  The slinger in this is also missing.  Was it commkon practice for the poles not to install this or have I managed to get two engines that have been serviced by the same meachanic who seemed to remove them?
GSXR126 - does you machines have them installed?
« Reply #4 on: October 14, 2010, 09:21:06 AM »
I never saw one in my engine either  :o
I noticed the pic was of a BIS engine, maybe it was only a BIS thing?
gsxr126
« Reply #5 on: October 14, 2010, 10:11:28 PM »
I will check it out on the weekend.
« Reply #6 on: October 14, 2010, 11:01:02 PM »
Just checked in 2 aircooled manuals and it seems the A/C does'nt have the thrower, just the Bis watercooled [-/
« Reply #7 on: October 14, 2010, 11:32:18 PM »
The aircooled has a different looking oil thrower than the one in the picture. It's a slightly cone shaped disc (that's what the manual calls it...)
Aaron
« Reply #8 on: October 15, 2010, 05:08:03 AM »
Ah well both my engines have the cone shaped device.  It sits behind the lock washer and retaining nut.
