Author Topic: wheels  (Read 6299 times)
robinoz
wheels
« on: September 26, 2010, 08:30:19 AM »
hi all just after a bit of advice for my 126 project anyone know if these wheels would fit straight onto a standard aircooled 126 cheers
http://cgi.ebay.com.au/ROH-13-MAG-RIMS-X4-/140455203541?pt=AU_Car_Parts_Accessories&hash=item20b3c852d5
4X 13" ROH MAG RIMS tidy condition look great with not too many scratches, one rim has a few little curb scratches on it, came with a barina i purchased but have never been fitted to it. nice looking rims will smarten up any 4 stud front weel drive car!! pick up only, item in berwick victoria 3806.
from centre to centre diagonally stud holes are 100mm apart
tyres are YOKOHAMA 165/70
Re: wheels
« Reply #1 on: September 26, 2010, 11:11:53 AM »
The wheels listed are GM/Vauxhall Corsa 4 x 100 PCD  -  42...45 Offset  -  56.5 Centre Bore
The Fiat 126 wheels are ......................4 x 98  PCD  -  30...38 Offset  -  58.0 Centre Bore
As you can see The PCD/Offset/Centre bore Are all Different + The Tyres Are the wrong size :(
This Site will help you with what wheels will fit, Check out Alfa/Fiat/Lancia  (Scroll down to the classic car section)
http://www.carlsalter.com/wheel_fitments.html
Eklipze3k
Re: wheels
« Reply #2 on: September 27, 2010, 06:57:28 AM »
As Pete said, all the important figures are wrong. The wheels could be made to fit if you could get a machine shop to enlarge the centre bore, get some 10mm spacers and wobbly bolts. Then you could change the tyres and Robert's your mothers brother.
edsaysyes
Re: wheels
« Reply #3 on: September 27, 2010, 08:43:25 PM »
Ok going to show my ignorance Whats wobbly bolts. I prefer it when the wheels dont wobble.
Re: wheels
« Reply #4 on: September 27, 2010, 09:06:00 PM »
edsaysyes
Re: wheels
« Reply #5 on: September 27, 2010, 09:09:26 PM »
Thanks Pete
Re: wheels
« Reply #6 on: September 27, 2010, 09:23:12 PM »
No Probs :)
Just thought i'd mention that if you use spacers you can't use wobble nuts as there is no way to centralize the wheel [-/
Eklipze3k
Re: wheels
« Reply #7 on: September 28, 2010, 07:14:48 AM »
No Probs :)
Hubcentric spacers ;) I've got a set of 14's for the Sei which are 4x100, 10mm hubcentric spacers and 40mm wobbly bolts and it all works perfectly :)
Re: wheels
« Reply #8 on: September 28, 2010, 08:01:39 AM »
The reason why i didn't mention Hub-centric spacers is because they are expensive, I can't see the point of buying a set of cheap second hand wheels then spend double the price of the wheels on adapters, If money's no problem then anything is doable :D
Eklipze3k
Re: wheels
« Reply #9 on: September 28, 2010, 08:46:32 AM »
Double the price?!  :o
Either you're buying hella cheap wheels (and if so, tell me where, lol) or are getting confused with hub adaptors to convert fitment from say 4x98 to 5x108. I know those cost well in excess of £150 per axle and are generally stupidly thick (like 25mm+), but simple hubcentric spacers are much less, the set I got were around £80 for all 4.
robinoz
Re: wheels
« Reply #10 on: September 28, 2010, 10:33:19 AM »
thanks for the advice i think ill keep looking for some 4x98 cheers all
Re: wheels
« Reply #11 on: September 28, 2010, 11:18:55 PM »
80 Quid.... :o  :o  :o
Bought These on Ebay some months ago Compomotive Sparko alloys with Abarth centres 98PCD-5.5j-13" The set £58 :D They need a little fettling and spraying up but they are a Classic Wheel and I think more suited to the 126 ;)
Robin, keep L :) :) king some wheels will turn up eventually their are still bargain to be had [-/
Alfons1972
  • sorry for my bad english...
Re: wheels
« Reply #12 on: September 29, 2010, 01:14:42 PM »
If you think of bigger wheels, why don't you think of those:
http://www.youtube.com/watch?v=LASh-bAJ8Ko
 ;D
Fiat 500 R
Fiat 500 giardiniera
Re: wheels
« Reply #13 on: September 29, 2010, 06:33:18 PM »
Ha ha ha, fantastic 22" wheels on a 126. Not really my taste :(, but the wheels are worth more than the car.
gsxr126
Re: wheels
« Reply #14 on: October 04, 2010, 11:15:22 PM »
I'd have to agree dajwid. I'm a fan of bigger wheels on any car but i think every car has a max size limit and 22s on a 126 seem just a tad too big. I'll stick with my 15s.
I didnt know they made 22" tyres that skinny, wonder what it would handle like :o
