Author Topic: DAJWID & the REV COUNTER  (Read 1308 times)
« on: September 21, 2010, 06:56:32 PM »
 :D Hope this message gets through to Dajwid after his kind offer of the rev counter. I did offer to cover postage & packing  in a PM plus some cash if it worked . Did not hear back from you . Does your listed  [email protected]  address work as I tried that also but no reply. I am not in a mad hurry but if there is a problem do let me know then I can look elsewhere  [-/
Re: DAJWID & the REV COUNTER
« Reply #1 on: September 21, 2010, 07:46:18 PM »
No I didn't read this sorry.
Sorted it out this weekend, it will go in the post tommorow. Don't worry about postage, I am sure we will meet up some day, you owe me half a cider.
« Reply #2 on: September 30, 2010, 06:05:41 PM »
 :D Dajwid my man if you are passing bye you can have some cider that I made from the apple tree in my garden. Thanks for sending the rev counter & I have had a play with it today. Worked out the wires , lashed it up , it works & seems to be giving the right reading as opposed to the other one I got . Shows my tick over which is set a bit fast is about 1300 rpm & when I pull the noise lever the engine will rev to just under 7000 rpm , in neutral of course  ::)
I will probably hook it up for a road run which should be interesting but due to its style & condition I probably will not fit it . But I think that it will be a useful tool with a couple of croc clips to monitor engine revs  [-/
