Author Topic: My Polski Fiat 126 - The saga continues  (Read 2010 times)
dionshorts
« on: September 19, 2010, 02:22:16 PM »
Hello again,
So after all the help everyone gave me before in regard to my 126 air cooled Polski Fiat back firing, stalling and generally not running well here's the latest which is worrying me as I fear it may be more serious.
First up I took the car in and had the Points and condenser changed which stopped the stalling but it was still back firing.
Took it back to the garage and they took the carb apart and cleaned it all up and then put it back together. Whilst the car ran better and back fired less the engine still sounded a bit 'rough' particularly when accelerating.
Got in the car just now and started the engine up and a loud tapping sound has now appeared. It's worse when accelerating or revving the engine. I'm concerned it might be a cylinder issue or 'big end'?
I had an old MK1 Ford years ago and a similar sound came from the engine when the 'big end' went.
It still drives but sounds like sh!te.
Anyone got any theories or good news for me!!??
Thanks everyone
Re: My Polski Fiat 126 - The saga continues
« Reply #1 on: September 19, 2010, 04:07:56 PM »
Don't panic  ;)
If your oil pressure light goes off and stays off the your bottom end will probably be OK. If you have not already done so then I would change the oil and check the tappets for condition & clearance. If no luck there then I would check out the centrifugal oil filter . If you have lost a bearing you should see some metalic particles in there  [-/
smallcox
« Reply #2 on: September 19, 2010, 05:07:47 PM »
Hi Dionshorts, yes don't panic :undecided2:
My theories is it's a fiat engine, they all tend to sound like this. As the car is air cooled this will amplify any nosies the engine has so loud tappets etc is norm. However a good run some times breaks or sorts the problem out, but as Rusty mentioned check your tappets clearance, this only takes about 20 mins to do yourself.
Does the noise get worse when accelerating or cruising or backing off the acelerator? is it a rumble or a knock? this would start to piont to bottom end bearings but if the car drives ok as you said then piston seal sounds ok, these pistons don't normally suffer with piston slap so thats good news.  [-/
As for rough running as above if bearings are good then these engine do not like to run over advanced and I find if you do run an engine like this the engines life is short. Ignition and fuel setting will upset the running of an engine and make it feel rough. :oops:
Good luck Smallcox
dionshorts
« Reply #3 on: September 21, 2010, 07:09:50 PM »
Thanks a lot for your help chaps.
Latest is that it looks like my head gasket. Not the best news!
« Reply #4 on: September 21, 2010, 07:47:32 PM »
Head gasket on an aircooled, Simples!! I changed mine, If I can do it it's not a big job. The car is far from dead.
« Reply #5 on: September 21, 2010, 08:25:54 PM »
Yes ditto Dajwid , you may have been looking at a total engine rebuild & big bucks. If it is only a head gasket then you have had a birthday  :D A boy scout with a Haynes manual and a suitable penknife could get his mechanics badge changing a head gasket  ;D
Where are you getting your advice from or have you removed the head yourself  ??? ???
