Author Topic: Steering Idler Box & Arm  (Read 1765 times)
« on: September 16, 2010, 07:08:16 PM »
Today's little task was to fit a new steering idller box & arm. Meaningless to you rack & pinion Guys  ;D
Anyway turned out a lot easier than I thought even though I just had the car front raised slightly with a bottle jack. Turned out that the one I removed had good bushes but the main bolt (or pin) was free to move when it should have been locked tight so the play was between arm & pin rather than worn bushes.
So poked a camera down there for the record , can you spot the little problem that I only spotted when I saw the picture on my computer  ??? :oops: ???
Re: Steering Idler Box & Arm
« Reply #1 on: September 16, 2010, 09:41:39 PM »
The wonders of modern technology!!
« Reply #2 on: September 17, 2010, 01:20:04 PM »
No eagle eyed guys out there then  :o
Eklipze3k
« Reply #3 on: September 17, 2010, 01:40:00 PM »
This stupid work PC won't let me see the full picture, I'll have a gander when I get home ;D
smallcox
« Reply #4 on: September 17, 2010, 03:43:51 PM »
Let me see, yes that's it, what a shame. no no. poor dude your NUTS are rusty, Rusty :oops:
« Reply #5 on: September 17, 2010, 04:28:53 PM »
 :no: No wrong answer , get back on the naughty step  ;D
No rust on the nuts I used , as there is a lot of exposed thread on the captive mounting studs I did the same as on my exhaust to manifold nuts and used stainless stud connectors , also found some heavy duty stainless washers then after greasing the studs I sealed the end of the nut with a short stainless grub screw. Cost of fixings about £4 but I know they are safe & there will be no corrosion problems  [-/
« Reply #6 on: September 17, 2010, 10:55:43 PM »
Oh my! I'd be very cautious of mentioning greased studs around heavy duty washers!! :oops:
I noticed it seems to be a 500 thing to have those long studs on the idler, can't think why they did that...
Sounds like a good plan you made there Rusty ;)
