Author Topic: Oil Pressure Gauge  (Read 2743 times)
Oil Pressure Gauge
« on: September 14, 2010, 02:01:27 PM »
OK so I know the Oil Temp Gauge works & just need to sort out the fitment at the sump . Easy with the Alquati sump as it has the extra boss. Thinking of just welding a boss / nut to a standard sump to test it out.
So got a new VW oil pressure sender from eBay , £12.50 , but wrong thread (1/8 npt) for the block (M10 x 1.5) so just got an adaptor also from eBay , £9.10 which arrived today , expensive but a nice bit of brass . So had to have a play  ;D
While I was fitting the unit I thought to myself that I had not seen the oil light coming on or off for I do not know how long  :oops:
I had just been looking at the generator charging light. Once I worked out how to remove the speedo head (just clips in) I then spent about half an hour trying to get the oil light working . No joy & thought I was in for some sort of rewire job . Had the manuals & wiring diagrams out ............................................to be continued  ^8)
« Last Edit: September 14, 2010, 02:04:46 PM by Rusty's Uncle »
Re: Oil Pressure Gauge
« Reply #1 on: September 14, 2010, 05:20:32 PM »
Part 2 - Finaly discovered that I was messing with the low fuel warning light instead of the oil preessure light  :oops:
So more time wasted as I tried to kick my own butt >:(
Reckon that it has been so long that the oil pressure warning light had been working that I forgot where it was.
So a picture of sender unit & adaptor & more to come ....................
smallcox
« Reply #2 on: September 14, 2010, 06:47:39 PM »
Hi Rusty,
Nice to see your still busy trying to upgrade your little passion wagon.
So fuel light now works?, can i kick your butt too?
I would be interested in your idle and running pressure at cold and after a good run [-/
Keep the good work up, your bested friend Smallcox
edsaysyes
« Reply #3 on: September 14, 2010, 07:10:33 PM »
Mmmmmmmmmmm passion wagon Theres an idea  My wife is only 4ft 9 so she fits
My girl friend is 6 ft do you think I should fit a sun roof then her head can stick out through it
smallcox
« Reply #4 on: September 14, 2010, 07:37:20 PM »
Edsaysyes, now i'am beginning to worry about you :o
« Reply #5 on: September 14, 2010, 08:42:42 PM »
 ;D Glad to see that you guys are getting to grips with the long and the short of it all  [-/
First time I met Smallcox he bit my ankle and he was standing up at the time  </4 </4 </4
So I replaced the long blown bulb then lashed up some wires to test the gauge  ::)
To my amazement it worked & as electrics are my worst nightmare I was well pleased  :D
The gauge is showing 5 kg/cmsx2 which equates to 70 psi on fast tickover which I think is a bit OTTP so there may be a callibration inballence but the needle is just above centre on the dial so well positioned to check out any problems  [-/
Now thinking of a cunning plan to fit gauges without disturbing the the original fabric of the car  ::)
« Reply #6 on: September 15, 2010, 12:13:02 AM »
Now now, no gauges in the seats Rusty!
Would be a cunning plan in the passenger seat if giving lifts to young sprightly members of the opposite sex....
I'll be interested to hear if the gauge you have reads fairly accurately as the digital one I had was a random number generator, hence it is back in box marked 'junk' :oops:
Sender and gauge came as a kit (thought I'd add that before the 5p's get added on that subject)
smallcox
« Reply #7 on: September 15, 2010, 03:18:30 PM »
Hi Rusty,
70psi at tick over does seem a little high as the pressure releif valve should be set around 40psi. (Has anybody moded the oil presure valve to increase it).
Must say though I like where you plumbed into the block as this is where when oil pressure starts to be a problem this will be the first place it will effect [-/   ie rear bearing
Whats your pressure when hot, but before you blow your fan up.lol
Smallcox
« Reply #8 on: September 15, 2010, 04:00:14 PM »
I only lashed it up for a quick test to see if it all worked so never went out on road or got the engine warmed right up. But I am leaving the sender unit on there & just using the oil pressure light connection. Interesting that the light flashed on today when I rounded a sharp right hand bend . The gauge may not be entirely compatible with the sender hence the reading maybe  ??? Anyway I can observe more when I get them hooked up properly.
« Reply #9 on: September 15, 2010, 08:14:53 PM »
Has anybody modified the oil pressure valve to increase it.
Smallcox
Many years ago you could buy stronger pressure relief valve springs which were used in high pressure oil pumps when you were rebuilding a fast road car engine for race or rallying. But to get back to the point when i rebuilt the bis engine a couple of years back i found some 1mm washers which were the right diameter and put 3 of them under the split pin that holds the pressure relief spring in place, I think its more difficult with the air-cooled because of the shape and bigger diameter of the spring, Couldn't tell what the psi is, Don't have an oil pressure gauge :( But if i did it would be something else to worry about ;)
smallcox
« Reply #10 on: September 17, 2010, 03:48:24 PM »
Know the feeling. You fit a gauge then spend more time looking at what it's doing than looking where your going. :PMAD :P
Thanks for that Pete because I was looking at increasing the Pressure to about 55-60psi any feedback out there?
Smallcox
« Reply #11 on: September 17, 2010, 06:18:23 PM »
I know where you are are coming from with this & remember that I only just discovered this week that my oil light bulb had blown, probably about 2 years ago  :oops:
So the gauge thing is not about trying to put some chav type dash together but more about what may lay ahead with modified engines & keeping an eye on what is going on in the engine department  [-/
« Reply #12 on: September 17, 2010, 10:42:59 PM »
What happaned to good ols capilliary gauges! :-
smallcox
« Reply #13 on: September 19, 2010, 05:23:06 PM »
Rusty I know your not a chav type person and a oil gauge is an excellent device to monitor engine condition. [-/
Ps how's the chav dash coming along? :P :P
« Reply #14 on: September 20, 2010, 05:16:18 PM »
 :D :D  Still waiting for the purple fur & colour changing leds to arrive. I was going to fit an authentic McDonalds cup holder but I am told that if you want to be truly chavtastic then you just throw the fast food containers straight out the window  :oops:
