Author Topic: The first gear shakes!  (Read 1962 times)
DC
« on: September 02, 2010, 06:27:10 PM »
i've recently replaced my whole engine and found now as i try to set off it shakes until it pops out of gear!  :(
instantly think dodgy clutch or gearbox so i spent yesterday afternoon swapping the clutch and gearbox back to the one i know works off the old engine  [-/ great lets go for a spin test it out . . .  **- . . . SHUDDER SHUDDER SHUDDER pops out of gear  :rant: anyone got any ideas?  :lease:
Re: The first gear shakes!
« Reply #1 on: September 02, 2010, 06:48:29 PM »
is the gearbox now sitting further forward than it was before as the posion of the engine and gearbox can be moved so that when you engage 1st it is only just engaged try loosening the gearbox mounts and slack off the engine mount and see if you can move the whole lot until it feels that the 1st and third gear engage better. as for the juddering i can only think that the clutch has not been adjusted correctly.
« Reply #2 on: September 02, 2010, 07:00:14 PM »
If the engine & gearbox are sitting comfortably in the mounts and it all lines up OK then check the position of the gear lever box. It bolts onto the tunnel on the right hand side into slots so you can adjust it back & forth  [-/
smallcox
« Reply #3 on: September 04, 2010, 08:29:51 PM »
Just my 10 cent worth,
But if 1st gear is not engaged correctly then it would just jump out off gear, not judder. I know you said you replaced the clutch but I would say oil contamination on the friction plate at first count, then gear box mounts.
DC
« Reply #4 on: September 05, 2010, 03:34:37 PM »
looking at the gear box mounts they are shot (hence the post in wanted for some new ones) but i still think its something mechanical as i don't think any amount of rubber could dampen the shaking. also it works fine in reverse and setting off in second!
smallcox
« Reply #5 on: September 05, 2010, 03:50:03 PM »
Gearbox mounts can play all sorts off problems so worth gettig them sorted as 1st gear will give the most torque and lift the box off it's mounts then knock it out off gear. Does it judder when pulling away gently in 1st?
Smallcox
« Reply #6 on: September 08, 2010, 09:00:56 AM »
i had this years ago, it would violently shudder in 1st. i tried everything - replaced gearbox mounts, engine mount rubbers i even had the flywheel skimmed and still nothing untill i checked the spigot bearing - the little bronze one in the middle of the flywheel. it was way oversize and slightly oval in shape so i replaced it and roberts your fathers brother!, it worked!! [-/ so it might be worth a look?
