Author Topic: The Great Ballast Resistor Debate !!  (Read 4048 times)
« on: August 31, 2010, 03:54:34 PM »
This is one of the topics that has made my head reel as there are those that say a ballast resistor is not necessary on the ignition & those that say they are important to protect the coil. Anyway as I lent my new spare twin spark coil out some time ago & had no back up spare I have bought a new one last week . When I looked in the box there was a little slip of paper that basically said to make sure that the + feed wire from the ignition switch had a resistance of 1.5 ohms. It was a Bis coil so how is that done on a Bis , do they have a ballast resistor ?
Fitted a universal 1.6 ohm ballast resistor from eBay now just in case  ::)
smallcox
Re: The Great Ballast Resistor Debate !!
« Reply #1 on: August 31, 2010, 10:21:09 PM »
Hello my old mucca,
Now Rusty you should not worry to much because how long have you been running your current twin coil on 12v without to much problems.
I too run the twin coil on 12volts for years only to burn points and condensor regularly but unless you leave your ignition on to long without your engine running then total meltdown will occur :oops:
The original system that fiat fitted did require a ballast off some sort weather be resistive wire or resistor but I believe your 321 ignition system will protect the coil when engine is not running and ignition is left on.  Also some electronic ignition systems do over volt the coil to supply higher output voltages if required, that is why they claim 10% more mileage when fitted (but we all know thats crap). >:(
 If you are concernd then there are several types off ballest on the market, I have fitted the ceramic type (about£6) and as you can see my engine runs fine even at high revs (remember Retro rides) [-/
If you are going to fit a ballast resistor then the 321 igintion must be bypass so full 12volts go to the 321 unit and where the 12 volt supply connect to the twin coil remove the +wire and in series fit the ballast resistor of your selection. [-/
Now is your head still reeling, to fit or not to fit that is the question
Smallcox :P
« Reply #2 on: September 01, 2010, 08:48:45 AM »
Well I have already fitted it , ceramic type , on the power in side of the twin spark coil  :D
« Reply #3 on: September 01, 2010, 03:38:45 PM »
I too have this. I haven't noticed any change since running without, but I guess it is there as a 'precautionary' measure. And I am addictedto buying bits and sticking them on, so it gave me a little pleasure in the process and something to do.
« Reply #4 on: September 01, 2010, 05:22:51 PM »
I find my girth is enough ballast to provide enough resistance... :oops:
« Reply #5 on: September 01, 2010, 05:39:02 PM »
i fitted a ballast resistor when i fitted my 123 and found that it would not start easily so i disconnected the ballast resistor and it resumed starting on the button as beforehand. the coil has been on with the 123 for a few years and is fine.
smallcox
« Reply #6 on: September 04, 2010, 08:37:21 PM »
Hi Bis13,
Was you running the original fiat twin spark coil or the later one which looks the same shape as a conventional coil, ie cylindrical? The reason i ask is because i asked if anyone knows the max output voltage off the twin spark coil as i have tryed capping the spark plugs at 1.5mm and they will still fire and run the engine. :-
Smallcox
Ps Darrell thats not what we heard about your girth
« Reply #7 on: September 04, 2010, 08:45:55 PM »
Bigger spark at 1.5mm?
My girth should be a little less soon, I've booked a week in Italy, I can see me walking the girth off! :P
smallcox
« Reply #8 on: September 04, 2010, 09:03:07 PM »
The theory off opening the spark gap would mean you can have a bigger spark, but gaps over 1mm will not have any advantage. Can we run at 1mm as fiat quote 0.65mm which is normally what you set conventional coils at so if some one knows the output voltage then we could work out the max gap we can set our spark plugs with out having problems.
I run the gaps on my engine at 0.75mm and at present all ok.
Ps are you going to be buying goodies for the car while in Italy
« Reply #9 on: September 04, 2010, 09:12:04 PM »
i replaced the original with the wasted spark type and have always run the 123 on that sorry as that will not help you.
« Reply #10 on: September 04, 2010, 09:15:55 PM »
The wife has packet a camera, and forbid me anywhere near fiat dealers... we'll see, as we speak |i'm lookimg-up dealers in Rome :P
I have had a BIS coil which died shortly after installing the 321 ignition set-up. It was replaced by an oil filled double chimney type. I took it off and examined it for you, no writing on it to mention voltage output. I guess we'll have to try test them somehow. Unless there is an electrical guru about who knows better.
All I know about my air cooled is that it says 12 volts on the battery, but when I put my tester on different spots it can be as low as 9V. Headlamps were running at 9V, now running through relays so voltage is higher.
Odd thing is the battery slowly looses charge, takes about 2-3 months to have to take the battery out to charge it...
Fiat = Faults in Alotof Terminals :)
smallcox
« Reply #11 on: September 04, 2010, 09:17:41 PM »
Hi Bis13,
I know you run the twin waste spark but is the coil the original fial coil or the coil that looks the same shape as a conventional coil, (cyclindrical)?wow that was a big word for me
smallcox
« Reply #12 on: September 04, 2010, 09:26:12 PM »
Hi Darrell,
don't mention headlight volt drop to me. Had nothing but dimlights so fitted relays and run a seperate power supply to the headlight which now seems to have cured the problem, even my indicators dont slow down when lights are switch on. :)
 The original loom runs a single wire from the battery to the fuse holder then every thing is distributed to the car so a voltdrop was going to be a major problem >:(
« Reply #13 on: September 04, 2010, 09:33:24 PM »
My indicators still slow down when the brake lights are on  :oops:
smallcox
« Reply #14 on: September 04, 2010, 09:34:36 PM »
Maybe you have discovered time travel?
