Author Topic: Good 126 Mechanic in London or surrounding area  (Read 2717 times)
dionshorts
« on: August 29, 2010, 05:02:09 PM »
I am looking for a mechanic in London or nearby who can take a look at my 126p (left hand drive Polski Fiat) I have taken it in to someone twice to try and solve a problem with the way its running and they can't seem to fix it.
My 126 backfires quite a bit and just isn't running smoothly as it used to until a couple of weeks ago.
Can anyone recommend anyone they have used before?
Thanks everyone
Re: Good 126 Mechanic in London or surrounding area
« Reply #1 on: August 29, 2010, 05:22:33 PM »
find a decent classic car garage and see what they can do dont use the local dealership or anyone you do not trust if you are having running problems then get your nose in the haynes manual and do it yourself that way one you will save money and two you will learn alll about the car. if you have any problems we are all here to aid you if it takes a little while to sort out then so be it but believe me by doing it yourself you will become intimate with the car and when something goes wrong in the future will be able to put your finger on it straight away.
« Reply #2 on: August 29, 2010, 05:27:45 PM »
Go to the nearest Polish shop, look for a mechanic in the cards in the window or ask in the shop. There are many polish mechanics in London all know the 126p inside out and will be very cheap too.
dionshorts
« Reply #3 on: August 29, 2010, 05:35:10 PM »
Thanks for the replies.
I have taken the carb apart and put that back together + changed the points but she's still just not very happy and isn't running well. Before I did that it kept stalling at traffic lights (low revs) unless I had the choke out.
As i said until a couple of weeks ago was absolutely fine. Not sure if it could possibly be linked but I have recently moved to somewhere with loads and loads of big speed humps which means that its hard to get any speed up (so the engine has to stop and start quite a bit) also (and this might sound silly) but I feel like the speed humps might be shaking the engine a bit and making it unhappy?!
I feel like I have reached the end of my car knowledge and really want someone who knows 126p's to have a look over it.
Given the number of Polish people who come up to me and ask me about the car and want to have a picture taken with it I am sure I can locate a mechanic somewhere if I speak to them. In fact as I type this a girl has just stopped outside my house and almost wept when she saw my 126 and is walking round it now looking at it.
If anyone can recommended anyone then please do post them up here. Thanks
« Reply #4 on: August 29, 2010, 05:55:22 PM »
I normally start with the fuel pump, thats where I normally have problems.
dionshorts
« Reply #5 on: August 29, 2010, 09:39:20 PM »
Fuel pump - interesting as I feel like I've been using more fuel than normal as well but I put that down to the fact I had been running the engine at higher revs at times to keep it running.
That would explain the lack of power and the engine feeling 'groggy'
Thanks for the advice
« Reply #6 on: August 30, 2010, 08:16:13 PM »
without the choke on what is the idle speed like? if it is too slow or seems to make the engine rock slightly then adjust the idle speed until it stops the engine rocking.
« Reply #7 on: August 30, 2010, 09:05:23 PM »
Speed bumps eh  ??? Well my car would almost die on me when I went over a certain speed bump at my local Tesco. Never could explain it. Did you change the condensor ? Also when you stripped the carb did you check the float chamber needle valve setting , may have been jarred on a bumpy hump. Also bumpy humps may have stirred up some residue in your petrol tank. Have you got an online filter  ??? You could also try a dose of Redex  [-/
« Reply #8 on: August 30, 2010, 09:14:48 PM »
When you changed the points did you check the static timing ???
« Reply #9 on: August 30, 2010, 09:29:28 PM »
You were also at that wedding I attended on Saturday note then? :oops:
Heathens getting married on a weekend! Made me keep clean all saturday and left me useless on sunday....all this when there is work to do on my fiat!!!!
dionshorts
« Reply #10 on: August 31, 2010, 10:48:19 PM »
I check all of that again - thanks for the suggestions.
Re: the back-firing (which sounds like an empty coke can being crushed quickly and makes my wife laugh a lot everytime it happens incidentally) do you think this would sound like the fuel pump as well?
The idle issue is pretty much gone now but does occasionally happen (as in my car stalls) - the main issue is the back firing and the general issue of the engine not running very well.
« Reply #11 on: August 31, 2010, 11:12:31 PM »
If its Backfiring on the overrun it more likely to be the ignition timing, If you have not already replaced the condenser I would ;D its a sneaky component and can cause all sorts of similar problems.
dionshorts
« Reply #12 on: September 01, 2010, 11:30:54 AM »
Thanks Pete126.
are condensers easy to get hold of ? I've found a lot of fuel pumps on ebay for about £30 so might pick one of them up as well just in case.
I've been trying to work out if they are the right one and the guy selling them has said to look at the picture on ebay and then at my pump to see if they match so hopefully I can figure it out myself.
Does anyone know which Haynes manual I should get as its not obvious from the Haynes website - did they even make one for the Polski 126's or will another one be fine as long as it is for an air cooled version.
Thanks again for everyone's - I've been riding old Vespa's for years and on some of the forums you go on for help you get given stick for being stupid and not knowing enough. Very different to this one where everyone has been really helpful.
« Reply #13 on: September 01, 2010, 12:44:09 PM »
There are two versions of the Haynes manual if you are looking at 2nd hand ones on eBay. The later version , up to 1987 , will cover pretty much all you will need. The early version 1972 - 76 also covers most of the mechanics. There are nearly always a couple on eBay and if the seller does not give a full description look at the picture as it shows the models covered on the front cover. A condensor is an easy part to get if you go to one of the 500 / 126 specialists . I think there is a list of suppliers on the forum. If you want one quick I would probably go for Franco at Ricambio or Chet & Toto at Ricambio 500 spares , both located South London "ish"  [-/
« Reply #14 on: September 06, 2010, 10:23:49 PM »
If you are after a Fiat 500/126 specialist in the London area, I can recommend Proietti Limited. This were I get my 126 Bis serviced. Okay, they are a bit pricey but they do get the job done. Here is their web address:
http://www.proietti.co.uk/
