Author Topic: Aircooled 126 starter motors  (Read 1730 times)
hotdeffender
« on: August 28, 2010, 09:57:48 PM »
My aircooled 650cc has a lever operated starter motor. Did all Aircooled models have this style of starter or did the later polish ones have key start?
Aaron
Re: Aircooled 126 starter motors
« Reply #1 on: August 29, 2010, 06:38:11 AM »
My polish 126 (1991 model) has a key start.
« Reply #2 on: August 29, 2010, 12:35:43 PM »
I thinks its been answered :)
Early ones had the handle, newer had key start.
Early are better, just watch a friend try to get in and rive away :)
« Reply #3 on: August 29, 2010, 06:11:59 PM »
If the cable breaks you can start your car with a broomstick  ;D
MADMALUCH
« Reply #4 on: August 29, 2010, 10:29:19 PM »
You mean John Clese style...give it a dam good thrashing...?
Sounds rough...i think its only running on two cylinders...?
« Reply #5 on: August 29, 2010, 11:35:30 PM »
No really, get a stick of some sort, put the igniton and choke on then push the button where the lever otherwise would via the cable from the engine bay  ;D (remember to have the car in neutral otherwise you can run after it...)
