After my massive overheating episode when my cooling fan blew one of the scariest things was opening the engine cover & seing the petrol vapourising in the plastic fuel filter which had blown up to more of a ball shape and the walls felt more like a plastic bag. I think that it was on the brink & if it had let go then it would have been a rather different story
So I had already picked up one of the aluminium filters that one of you guys recommended a while back and have bought some 6mm bore stainless braided hose complete with rubber end fittings & stainless clips. Then spent about an hour trying to get one rubber end fitting over the frayed ends of the braided hose
Stepped back & had a rethink , nothing on Google then used a little insulation tape around the end of the hose with a slight overlap at the end so the steel strands were tied in but not so much that the tape might interfere with the pipe bore. End finishers then popped on in seconds [-/ Sorted
