Author Topic: First outing!  (Read 3058 times)
ypsilon_lancar
First outing!
« on: August 26, 2010, 08:13:47 PM »
Went for my first outing today since getting my 126 (aircooled)  8) it drove  **- fine for an hour, then i ventured onto the M62  :o
The car started juddering and popping, loosing power. I got off at the first junction and it wont idle. Keeps cutting out unless the choke is on.  Its running a bit lumpy now and keeps back firing when i slow down.  :cry:
any ideas on whats going on? I drove it from Huddersfield to Doncaster when i bought it and had no issues, apart from a sticking choke its always been fine on idle. It happened as soon as i hit 60mph  :eek: (and just before the odometer hit 10,0000!!)  :(
Any suggestions would be greatly appreciated as i want to go out in it now that its finally road legal!!  :lease:
Re: First outing!
« Reply #1 on: August 26, 2010, 08:23:26 PM »
Classic fuel starvation.
Check the fuel system
Pump
Filter
Float valve
Normally it's the pump.
The engine casing expands leaving the rod too short to push the pump.
ypsilon_lancar
Re: First outing!
« Reply #2 on: August 26, 2010, 08:28:33 PM »
Cheers Darrell  [-/
I half suspected it but being new to the 126 world wanted to get some expert advice! The fuel filter did look a bit low so i will go through it all in the morning.
The engine bay seems to get really hot on it, might sound like a stupid question but is that normal?  </*
Re: First outing!
« Reply #3 on: August 26, 2010, 09:06:52 PM »
All signs of fuel starvation, a lean running engine will run hotter,
Re: First outing!
« Reply #4 on: August 27, 2010, 06:59:07 AM »
A regular thing to check on any air cooled engine is the two nuts that hold down the carb onto the head. They have a habit of working loose so you end up drawing in air there.  [-/
Re: First outing!
« Reply #5 on: August 28, 2010, 09:46:02 AM »
you and your two small nuts...
ypsilon_lancar
Re: First outing!
« Reply #6 on: September 03, 2010, 11:17:35 PM »
That was the first thing i checked as i had read it before on here!  ;D
I cleaned the filter on the carb and its been fine since even on a 4 hour drive! Touch wood it was a one off event!!
ypsilon_lancar
Re: First outing!
« Reply #7 on: September 04, 2010, 12:13:28 AM »
Oh my rear light stopped working as well, trying to figure that one out. It was off, i bought new bulbs and it decided it wanted to work. Then it changed its mind again. Changed the bulb and nothing, the brake light works fine, just the tail light! Took the whole unit out (breaking yet another platic screw!  >:( ) and nothing loose or funny looking. Need to get the multimeter out i think!
Re: First outing!
« Reply #8 on: September 04, 2010, 06:40:15 AM »
Have you checked that the fuses are clean & reated properly  ???
Re: First outing!
« Reply #9 on: September 04, 2010, 10:57:02 AM »
the connections do tend to get a bit pooty give them a bit of a clean up also the circuit boards tend to give up ive had a couple stop working and when this part has been swapped i got my lights back. another thought is are the bulbs the right way round as one set has two fillaments?
smallcox
Re: First outing!
« Reply #10 on: September 04, 2010, 08:22:43 PM »
When I fitted my bulbs I got daffodils.lol
wheres my wiring diagram, thats the trouble with being married it gets moved to god knows where. Well from my memory the tail light are feed from two seperate circiuts so start buy touching the fuses to see if it flashes on because the connections in the fuse box cracks. Bloody wife.
ypsilon_lancar
Re: First outing!
« Reply #11 on: September 05, 2010, 08:01:06 PM »
Cheers for the suggestions guys. Im off work tomorrow so i can have (another) day of 126 things!  ;D
ypsilon_lancar
Re: First outing!
« Reply #12 on: September 06, 2010, 12:40:46 PM »
Checked everything and still nothing! The number plate light for that side (running on the same bit of the loom) works fine. Im going to try and find a new PCB and see if that works.  On the plus side today i painted the headlamp bulbs amber which cheered me up!  :)
ypsilon_lancar
Re: First outing!
« Reply #13 on: September 10, 2010, 09:36:11 PM »
I cheated in the end and ran one of the number plate light wires to the tail lamp which has worked! Need to get everything prepped for paint next. I have got a nice Mica Grey colour
