Author Topic: Head gasket done now what?  (Read 1326 times)
K666STW
  • 704cc of pure fury.
« on: August 24, 2010, 03:56:36 PM »
Well the BIS blew it head gasket on Friday. Top marks to Ricambio ordered a copper gasket at 2:30 on the friday and when I went down to my dads to start stripping it down the Saturday it was sitting waiting for me. Anyway The car is all back together and seems to be better than ever. I suspect the gasket has been slowly on it's way since I bought it.
But my reason for this thread, now that I've done the gasket is there anything else I should really do to it. I've flushed the oil and coolant once and will do it again in a week, but I've read about removing the thermostat but is that still needed with the copper gasket or only if you put a standard one back in?
Re: Head gasket done now what?
« Reply #1 on: August 24, 2010, 08:59:42 PM »
it all depends on why the gasket failed if the car was overheating and caused failure then you will need to monitor the temperature closely take out the thermostat and test it to see if it is working check that the car has a good amount of coolant and not just good old h2o as this will cause the pipes and water jacket to get shi**ed up there is a well known fix of relocating the temperature sender closer to the head so that the system works better but for the moment just ensure you have no airlocks and that the fan kicks in when it should.
K666STW
« Reply #2 on: August 24, 2010, 10:10:12 PM »
Well I don't know why it failed, but the car is maintaining it's temp around the halfway mark now with the fan coming in as it's supposed to.
I only noticed it was wrong when it was over heating and then it swallowed over 6 litres of water. Though I found most of that in the exhaust and the oil later on. :)
