Author Topic: Which engine models fits in a fiat 126 p from 1986  (Read 1852 times)
fnuuky
« on: August 22, 2010, 02:49:52 PM »
Hello. I will buy a fiat 126 where the cylinder head is broken. I therefore think it would be easiest to change the whole engine so I have no problems. But fit a motor from a model 1995 in a Fiat 126 from 1986? Without some problems with the wiring to the engine, etc. Or which models will fit in a 1986 model?
Hope you can help me, and sorry for the bad english :)
Eklipze3k
Re: Which engine models fits in a fiat 126 p from 1986
« Reply #1 on: August 22, 2010, 05:18:33 PM »
If your car is aircooled and you are fitting an aircooled engine then you'll be fine, if it is watercooled (BIS) and you are fitting another watercooled engine then you'll be fine. It's when you try to put aircooled into BIS and vice-versa that you'll have problems.
fnuuky
« Reply #2 on: August 22, 2010, 09:48:04 PM »
Okay thx :)
So the engine is the same, as it always has been ? :) nearly ;)
« Reply #3 on: August 23, 2010, 08:07:56 AM »
Newer engine will have E ignition and I think will run unleaded depending on which year the newer engine is. Still basicly the same engine though, different carb to. I think :oops:
fnuuky
« Reply #4 on: August 23, 2010, 11:51:25 AM »
Okay thanks.
So a ELX with kat will also fit in a model 1986 ? So in the ELX it's only the kat and the E ignition there is different ?
