Author Topic: Thermostate movement  (Read 3062 times)
Worm
« on: August 21, 2010, 11:40:19 AM »
Hi have taken off my thermostat from my 1983 aircooled 650 126, and done the dunk test in boiling water. From closed position to fully open (94 degree C) it expanded by 10mms. Is this the normal travel or should it be much more? Thanks ;)
Worm
Re: Thermostate movement
« Reply #1 on: August 21, 2010, 06:47:30 PM »
Measured the rod movement/travel and that was 13mm so yes i think i have answered my own question here ;), my thermostat operates ok.
phreak97
  • Niki!
« Reply #2 on: August 24, 2010, 01:37:41 PM »
usually they either work fine or they stay in the open position, theres not much possibility of it getting stuck closed or not opening far enough.
the mechanism is just a concertina full of alcohol. when the alcohol heats up it expands, extending the concertina.
the only likely failure is a leak in the concertina bit, which results in it staying extended, sucking air back in when the alcohol contracts
phreak97
« Reply #3 on: August 24, 2010, 09:02:20 PM »
so what happens when the bellows crack and all the alcohol is lost? it closes..... ;)
Worm
« Reply #4 on: August 25, 2010, 09:31:08 AM »
The rod and flap mechanism seems sprung loaded and the flap is in the open position with no thermostate attached. Ie with the thermostat removed the flap is open and the rod has travelled the 13mm downwards. In order for me to reattached the thermostat i had to block up the flap to the closed position to raise the rod in order for me to reattach the thermostat (a fiddly job but you dont have to remove the cover etc that looks a pig to do).
So if the thermostat is cracked and all the alcohol gone i would say that the force of the flap mechanism spring would easily over come the empty bellows and the flap would be in the open position all the time ie at cold start too. [-/ as phreak97 has also stated.
I would assume the thermostat at manufacture is sealed with the alcohol under vacuum thus being enough opposing force to overcome the rod/flap mechanism spring at cold start, or perhaps they put in really cold alcohol, who knows!! </3.
« Last Edit: August 25, 2010, 09:36:35 AM by Worm »
phreak97
  • Niki!
« Reply #5 on: August 25, 2010, 10:59:12 AM »
yeah thats correct, the flap opens and extends the bellows if theres a leak.
the car will run alright with no thermostat bellows, but it takes longer to warm up and the heater will do next to nothing.
the engine casing on the thermostat side is actually very easy to take off, the trickiest part is marking the distributor so you dont upset the timing. the distributor is geared onto the cam so you have to mark the rotor (or where a rotor would be) position accurately as well as the dizzy position itself.
to get the casing off, first whip out the dizzy, then it's just 7 or so bolts. the back of the motor is the same as the front except it has a welded nut where the little bolt connects the two halves of the housing together, so it's even easier.
in my 1 hour lunch break I managed to eat lunch, pull that casing off, take the thermostat bellows out, install it in another casing, then put the new casing in. I was putting it off because I thought it'd be a prick, but it really wasnt.
my housing had broken around two of the rear mounts and at both ends of the thermostat flap so it was just hanging loosely by the bellows connecting rod, the heater takeoff pipe had also snapped off previously, been reattached, and snapped off again.
it was time for replacement:P
but yeah, all of this is still pretty fresh in my mind, I only did it last week.
phreak97
Worm
« Reply #6 on: August 25, 2010, 11:58:30 AM »
Well i did the short cut route literally only took me 6 hours (3 minutes to remove thermostat nut and cover, slipped with tool trying to get split pin out, sliced my pinky deep on the threaded stud, stopped for 5 hours while i cried in the corner and put some butterfly stitching on it kissed it all better, returned to removed stat [-/ 10 mins testing it, 15 reassembling it) was wearing fingerless leather gloves too, so only took me 23 minutes plus 5hrs37m to mend me ;D
phreak97
  • Niki!
« Reply #7 on: August 25, 2010, 02:12:53 PM »
ah ouch lol.
Id say youre right, its quicker to leave the casing on.. I was just saying it does come off alot easier than it looks.
phreak97
Worm
« Reply #8 on: August 25, 2010, 03:22:38 PM »
yer i know you were [-/
« Reply #9 on: August 25, 2010, 05:26:43 PM »
i sound like a total cop out as i took off the whole housing and have never put it back the amount of time it takes to warm up doesnt take long and i dont have any of the heating piping/tunnel in place anyhow.
« Reply #10 on: August 25, 2010, 08:03:49 PM »
It's like a BIS doesn't need a thermostat either.
But I have done some mods to my heater cowling to make it easier to get on and off. One thing that helps is to 'forget' to put those stupid bolts in, the ones that go through to the ring around the combustion chamber, forgot what they called.
But I agree with bis13, summer running take the silly cowling off! Makes it easier to get to the dizzy and easier to see any leaks.
phreak97
  • Niki!
« Reply #11 on: August 26, 2010, 02:16:02 AM »
lol, so long as you leave the other side of the cowling on.. otherwise it might be heating up alot faster than you want:P
I made sure ALL my bolts were secure.. I'll take photos of my old housing and post them soon, I can only assume the damage was done because it was a bit loose.
phreak97
