OK all replaced will post a pic soon, however the haynes manual for an aircooled says that the top nut on the stub axle is 44ftlbs and the bottom which connects to the spring 29ftlbs, is this the same for the Bis?
Also it says tighten them after the wheels are back on the ground to avoid distorting flexible bushes, but I have found that this is near impossible can it be done without the wheel on is it really a problem?
Ta
