Author Topic: Fuel Line size/type advice  (Read 2127 times)
Worm
« on: August 18, 2010, 12:31:57 PM »
Hi i am going to replace my fuel lines on my 1983 650 aircooled 126. The existing lines seem to have once been transparent but now turned brown so can not see if there are any air bubbles in lines so pretty old i guess.
The OD is 8.5mm, each wall thickness is 2mm which leaves a bore of 4.5mm! The fuel pump inlet/outlet have 6.3mm diameter shafts with 7.5mm diameter end cones. The existing fuel lines seems a little stretched over the shafts.
Firstly what size should i go for? the 5mm or 6mm ID bore size?
Secondly I have looked on line and come across various clear PVC pipes claiming to be suitable for Fuel lines. I would like to keep clear hoses ideally for future observation purposes only, to monitor the fuel and any air bubble problems. What do people use on theirs? the black rubber hoses (are they safer) are do you stick with clear?
Thanks for any advice on size and type (clear/rubber).  And suppliers info to buy some [-/
Re: Fuel Line size/type advice
« Reply #1 on: August 18, 2010, 08:22:02 PM »
I replaced all the fuel lines myself with the black 6mm rubber petrol hose. The originals were probably 4mm so you could go for the plastic pipes if you want to see the fuel flowing in the line (the line going from the fuel pump to the carb has that rubber ring on it so you can catch it into the fuel line clamp). I was only worried with the 6mm hose coming from the tank as it first looked as if the tank would squash it into the chassis but there was enough clearence there. Make sure the hose clamps/brackets you have are in good condition as the originals rust (mainly the ones at the tank). You might find fitting the pipes  easier using new brackets.
Allan
« Reply #2 on: August 18, 2010, 10:45:54 PM »
If I was going to use clear fuel line I would try to get the origional Cavis brand stuff. The size is interesting. I have just measured the pipes on my brand new pump and they are 6.3mm which in fact means they are 1/4 inch so 6mm would fit real snug. Because of the heat generated around the motor I would prefer to use a braided line such as is made by Wurth. BUT be careful because not all "fuel lines" are equal. We had some cheap stuff we used on the likes of Uno etc and after a couple of months it went soft and started to ooze. My advice is use a good quality hose with new clips that are the correct size for the job.
Allan
Worm
« Reply #3 on: August 21, 2010, 01:34:58 PM »
Yer thanks for advice, i think i will use the black rubber type from tank to pump, then maybe some clear from pump to carb all in 6mm ID.
Worm
« Reply #4 on: August 23, 2010, 03:38:17 PM »
Ordered some 6mm ID braided 5m of it for £22, that should do the job nicely [-/
