Author Topic: The Brakes  (Read 1532 times)
Jackal
The Brakes
« on: August 12, 2010, 11:37:20 AM »
Hi there guys, just after a spot of advice.
I've just passed my test and bought my first motor, a little old 126 of course.
And now to the problems.. When i push the brake pedal it goes down about an inch, maybe two, and then nothing, like stepping on a brick after that. There is also a slight imbalance with the brakes, when pushing the brake pedal down all of it's inch the car veers slightly to the right. From what i can tell it's had new shoes and drums on. It's off the road at the moment until i can hopefully sort a few things out on it.
Also, does anyone know a rough idea of how much it would cost to have discs fitted instead of the drums?
Any help would be much appreciated, cheers guys.
Re: The Brakes
« Reply #1 on: August 16, 2010, 07:34:34 PM »
The cars do not like standing outdoors or in damp conditions for too long . Sounds like a bit of seized wheel cylinder. Is it a Bis or an air cooled  ???
Jackal
Re: The Brakes
« Reply #2 on: August 20, 2010, 05:31:55 PM »
Thanks for the reply rusty! It's a bis i do believe, 1988. It's being stored in a barn at the moment to keep her out of the awful weather
Re: The Brakes
« Reply #3 on: August 20, 2010, 06:49:44 PM »
The front disc conversion can be done quite cheaply on cars running 13" wheels . If you do a search on the forum section you should find loads on there  [-/
