Ok, here goes:
After the crash i found that there was too much play in the bearings up front and didn't tighten the rear ones with a torque wrench 'cause i didn't have one at the time. Torqued them all up as in the service manual. Rear ones no problems (didn't need to tighten much) front left was perfect, front right was a bit rough. Oh well i thought i'll just replace it. Replaced it, torqued/adjusted, drove 30kms and it started rumbling. Got home, wheel and drum off, grease everywhere, hub off, outer small bearing destroyed (literally, there were fine metal particles in it). Bashed hub seal back in anger as it had slipped out, put in a used but good bearing, torqued and off i went. Went for a while and same thing happened. Left one in the mean time no problems. Replaced with new bearings and seal (proper metal housing type not the rubbish new types) and torqued. Went for a while and decided to check up on things. Good idea as this is what was with the left wheel bearing:
