Fiat 126 Chat
Front brake spings?
Pages: [
Topic: Front brake spings? (Read 1446 times)
Front brake spings?
on:
August 11, 2010, 02:08:39 PM »
Put new shoes on the front brakes but what is the best way to refit the springs?
Eklipze3k
Re: Front brake spings?
Reply #1 on:
August 11, 2010, 02:55:49 PM »
I found the only way I could do it was to attach the springs to the shoes away from the vehicle and refit the assembly as a whole. Fiddly, yes, but easier than trying to stretch the springs with the shoes in situ.
Reply #2 on:
August 11, 2010, 06:29:11 PM »
I fit with top spring in place and fit the lower using a wire to pull the spring and pop the end in with a screw driver, works for me.
Reply #3 on:
August 11, 2010, 06:38:22 PM »
Thanks guys, managed to do it now with a couple of grazed knuckles
Allan
Reply #4 on:
August 11, 2010, 09:32:37 PM »
The best way i have found is to use the 6 inch long pin thing that comes in the tool kit and is used for turning the spark plug socket.
If you modify the pointy end a little by grinding a small step about 4 or 5mm long it should work.
Put the spring into one brake shoe and slide the tool through the hook in the other then put the modified end of the tool into the hole in the other shoe and just lever it into place. It doesn't always happen first time but it will go on.
Allan
Pages: [
Fiat 126 Chat
Front brake spings?
