Author Topic: Scary moment on way home from work  (Read 1986 times)
gsxr126
« on: August 05, 2010, 12:47:04 PM »
I was about 1km from home and suddenly smelt a strong fuel smell. Pulled over and found a small fire in the engine bay. Whipped off my shirt and put it out. The brass fitting and fuel return line had come loose and was resting on the exhaust. Luckily it didnt burn thru (just) but fuel was still dribbling out of the carb and flaming up on the hot exhaust. Found a small twig and stuffed it into the fuel return hole, cable tied the burnt fuel return line to the engine hoist bracket, said a prayer all the way home, and got there with no dramas.
Have just fixed it and taken it for a run and all is well. I applied loctite to the brass fitting, cut the burnt bit of line off and reconnected it. I gave the carb a good clean while i was there as it was a carb off job.
I would recommend anyone with a 28IMB weber (std niki) check their brass fittings for a tight fit. A teltale sign is leaks around them and fuel puddles on the rear of the base plate. The potential for disaster is enormous.
Worm
Re: Scary moment on way home from work
« Reply #1 on: August 05, 2010, 01:02:08 PM »
 :yikes: Ekkkk, Very intuitive using the materials around you to make a quick fix.
I will add a few twigs to my tool box now </8
« Reply #2 on: August 05, 2010, 02:50:07 PM »
GSXR I reckon you are just attention seeking  ;) It was a small fire & it was only petrol  :oops:
I know you guys rip the sleeves off your shirts so they do do not get in the way when you are putting out fires  [-/
Now if you had wrestled a croc to extract a suitable size tooth to jam in the hole that would have been a story !
</4 </4 </4 </4 </4 </4 </4 </4 </4 </4 </4 </4 </4 </4 </4 </4
On a more serious note that is a well documented problem with the 28 IMB carb & I am running one on my 500. I was thinking of fitting the fuel return line but I think that you have just convinced me to drill out & tap the hole & block it with a screw. The 500 cars with the 26 IMB did not have a fuel return line  [-/
gsxr126
« Reply #3 on: August 05, 2010, 03:46:43 PM »
Tried the croc tooth first but it wasnt a tight fit so had to settle on the twig. ;) Also selling two shirtless sleves at a bargain price :D
I am also going to block the return line as ive heard it doesnt affect the carb in any way and would prefer eliminating the potential for it to happen again.
I'm thinking a fuel return line on a 500 would be an involved mod as would you not need to modify the 500 fuel tank to accept a return line???
« Reply #4 on: August 05, 2010, 06:43:08 PM »
The 126 sender unit will drop straight into a 500 tank so you can get the return inlet. The pain would be running the pipe up the tunnel.
Anyway found another account of a similar incident that happened in good old England  :D
"Crikey chaps I was motoring in the trusty 126 when I thought I caught a wiff from the back end. Pulled over to find the engine compartment ablaze. Acting in haste I put up my brolly to shield the scene to protect women and children & not alarm the public then thrashed out the flames with my bowler hat. Damn fuel return line had come adrift so tied it back with my silk cravat then prised a jolly large pearl from my cuff links to seal the hole in the carb. Made it to my club with time to spare"
True Story  ;D
« Reply #5 on: August 05, 2010, 07:42:10 PM »
To block off the return in a 126 may cause some problems with a build up of presure in the supply side particularly with long journeys, the 500 pump delivers less fuel than the 126 well thats what I've been told.
« Reply #6 on: August 05, 2010, 10:58:25 PM »
Bugger that with patching-up a car like that! Just get the natives to carry the car home, souldn't be too bumpy. Surely a G&T can be sent for and some reading matter!
Don't be tempted with the old stick it on an elephant thing, they startle when the see mice and the tow home behind a zebra requires too much concerntration.
Try warming the carb a little with a blow lamp and then shoving the fitting back in with your magic locktite stuff. In the factory apparntly they did that.
MADMALUCH
« Reply #7 on: August 13, 2010, 10:07:22 AM »
Out here in Poland i have a friend who is a member of the local Straza .( fire brigade )   He tells me that he has attended many a blazing Maluch due to petrol or oil leaks...
When i collected my own Maluch , i drove it home with an oil leak from a missing exhaust bolt , which went straight onto the hot exhaust...fortunatly , being minus 20 , it was reuctant to actually catch fire....!
Sounds rough...i think its only running on two cylinders...?
