Author Topic: MOT story  (Read 2104 times)
chrisrhodesinlbz
MOT story
« on: August 02, 2010, 08:32:33 PM »
Hello fellow forum members!
It's a bit late for mechanical advice, but I booked my 1988 Fiat Bis in for an MOT last week, it was a bit overdue, but I wasn't overly concerned cos it passed easily in 2009, and I had only done about 1,200 miles in the last 12 months. Although I suppose in its 22 years that is a big proportion of the recorded 16,000.
There were a list of problems the main ones being worn wheel bearings and brake cylinders leaking. One wheel bearing was replaced and all 4 brake cylinders were replaced, admittedly there was a service done too, but it came in at a whopping £593 (including labour at £50 per brake cylinder, plus the cost of an MOT and service). I was away from home and really just wanted the car back with an MOT, so went ahead with it all. Is that a lot do you think?
Eklipze3k
Re: MOT story
« Reply #1 on: August 02, 2010, 09:18:21 PM »
The cylinders only cost about £10-15 each so yeah, that's pretty steep!
Re: MOT story
« Reply #2 on: August 02, 2010, 09:38:38 PM »
I'm not surprised!!! most garages are charging £50 to £100 an hour for labour, But at least you'll have the car back on the road and without dirtying you hands ;)
Re: MOT story
« Reply #3 on: August 02, 2010, 10:00:46 PM »
Hi Chris , a lot of your problem was explained in the first sentence in that you have only done 1,200 miles in a year. By all means look after your car & polish it but they were meant for driving , bit like walking your dog. The wheel bearing apart , although at that mileage a little surprising , you have paid a big price for not using the car and when you are at the sharp end of an MOT fail you are backed up against a wall & have to pay top dollar. Very hard these days to find a garage that will not rip you off but The Old Dairy Garage in Tring  is not too far from you and they are good guys, failed my Seat last week though quite rightly , just brake pads though  [-/
Re: MOT story
« Reply #4 on: August 02, 2010, 10:11:40 PM »
If ones car fails a MoT for whatever reason and am unhappy with thier assessment. Can I, for example take the car to another MoT test centre?
Re: MOT story
« Reply #5 on: August 02, 2010, 10:18:25 PM »
If it has failed then it can only be driven to and from an appointed MOT centre, but, there is nothing to stop you from taking it to a number of different MOT centresas long as an appointment is booked first. Having said that, if it looked as if the car has failed unfairly then its worth having vosa test it because it will flag up the problem of a dodgy MOT tester.
Re: MOT story
« Reply #6 on: August 02, 2010, 10:52:04 PM »
If ones car fails a MoT for whatever reason and am unhappy with their assessment. Can I, for example take the car to another MoT test centre?
With the new MOT certificates all the faults/advisories on the failure certificate are stored on the DVLA computer so if you take the car to another MOT testing station, when they log your car on to the DVLA computer those failures/advisories will be flagged up, So its a no win situation, As Michael mention there are Official Vosa testing station so you can take your grievance up with them.
Re: MOT story
« Reply #7 on: September 29, 2010, 12:11:15 PM »
I got my car MoT's today. It went through with no advisories! Hurray!!!!! The good thing was that the tester was Italian and quite familiar with the 500 and 126s, having owned quite a few of them. He did mention, however, that there was a very slight play on the front two wheels, the bearings need to by adjusted slightly. He added that it is quite normal to have a slight play on the 500 and 126s. Is this correct?? He added that tightening the bearing (screw?) too much could result in the bearing wearing out too quickly. He did not issue an advisory but thought he should mention it to me.
Re: MOT story
« Reply #8 on: September 29, 2010, 02:59:58 PM »
The tip is to take your car to a MOT centre that tests lots of classics as they are more sympathetic to the quirks of some older vehicles where as the local quick fit will compare it against a modern car and fail it time and time again.
I advise strongly that if you consider complaining about a test result will mean that you will then have to take the car to a vosa test centre and they will go through the mot again, this could result in you ending up with a bigger list as the vosa testers are far less forgiving and will inspect other areas not covered by the mot and this could spell major problemos.
Re: MOT story
« Reply #9 on: September 29, 2010, 03:48:05 PM »
Mine's just gone through an MOT.
I simply jack it up and check for play in the wheels, check lights and have a good dig around underneath. They always seem to need a tweek on the wheel bearings, it in my opinion does mean they need new wheel bearings. Overtightening will kill a bearing  :-X
It went through with an advisory of a worn tyre close to the limit, and a knackered chushdrive CV thing on the right.
The MOT tester did not pick-up some of what I thought was a bit close to the limit so beware, taking it to VOSA will probably flag-up even more problems!
Do a mini MOT test yourself first, all you need is a jack [-/ then you'll pretty much know if the tester is pulling the wee wee :oops:
