Author Topic: Various questions  (Read 3139 times)
Draigflag
  • Got a New Abarth 500 too!
Various questions
« on: August 01, 2010, 08:40:09 PM »
I'm too impatient to read the Haynes manual for the 126 BIS (is there even one for the BIS?) so i thought I'd ask a few newbie questions of things i really should know the answer too, but I've never owned a 126 before, so i don't! Please be patient with me!
1. When the tailgate is opened, there is a filler cap on the L/H side, is this the water level? If so, how do i check if it needs topping up, i can't see any reservoir?
2. There are 2 bag type things with fluids in under the front bonnet, one on the right one on the left. Presumably one is for the wipers, but which one? And what is the other one for?
3. Took her for a quick spin, 1st time in almost 10 years (she's been SORN since 2001!) drove really well considering, although under heavy braking, she pulled to the left. How can i fix this? Would the brakes need bleeding?
4. Had a scary/hilarious moment on the way home, engine went suspiciously quiet, then suddenly BANG! a backfire loud enough to scare my Abarth 500! Presumably she stalled then started back up again and fuel went into the exhaust, but what would cause this?
I also captured her backfire on film! here's the video!
Thanks in advance guys  [-/
Re: Various questions
« Reply #1 on: August 02, 2010, 09:44:32 PM »
I am a novice on the 126 Bis but here goes:
1. Yes. The only time you will need to top up is when the light on the dash lights up (engine coolant symbol). Do this when the engine is cold. Do not remove cap when engine is hot.
2. They are for the wiper wash. One for the front and one for the rear screens.
3. The cause of this could be another of things. It could be a sticky caliper, worn brake pads, loose ball joint, or loose tie rod end. The pulls during braking can come from the front brakes, rear brakes, and sometimes, not from the brakes at all! Loose or worn steering or suspension components can also cause a pull. A pull  that happens abruptly can be caused by loose suspension components. You need to get this fixed asap.
4. The backfiring could be caused by ignition timing, rich fuel mixture, or valve timing etc.
It is quite hilarious coming from tiny car like a 126.
Draigflag
« Reply #2 on: August 02, 2010, 10:40:46 PM »
Thanks for your help  [-/
Hopefully the backfires won't do any damage! Also, will she run on unleaded? I've read everywhere that she will, but the guy i bought it from insisted i put some lead substitute in!?
I'm not using the car much, she won't be back on the road until next summer as i left it a bit late this year with tax, insurance etc, so all of the above are only minor concerns at the minute.
Eklipze3k
« Reply #3 on: August 02, 2010, 10:42:31 PM »
I ran my old aircooled on unleaded no bother but was designed in the 4-star era so I really ought to have been using additives, I'm pretty sure the BIS engine was designed for unleaded.
bardy
« Reply #4 on: August 02, 2010, 10:52:31 PM »
the brouchur for the BIS says it can run on unleaded or leaded fuel so yes it can
Draigflag
« Reply #5 on: August 03, 2010, 07:00:56 PM »
That's what i thought. Thanks again. Expect more questions in this thread in the near future!  :)
Draigflag
« Reply #6 on: August 13, 2010, 08:10:05 AM »
The black plastic clips/pins holding both the interior carpets and the plastic sheet under the bonnet, how are they removed? I want to lift the carpets, but when i pull on them it feels as if they're going to snap!
« Reply #7 on: August 13, 2010, 04:07:14 PM »
I sort of try to lift them up on either ends together carefully. Once I get hold of it, twist it about but be careful not to break the head. It should not be too difficult to pull out. It is cheap to buy at 126SKfan and other suppliers if you break them. I am not aware of a special tool to remove them.
Draigflag
« Reply #8 on: October 29, 2010, 06:20:21 PM »
I thought of another question. Gear knob - mine seems to spin, and spin, and spin. How does it come off and can you put a universal custom gear knob on? (bearing in mind, the BIS has a push down reverse)
« Reply #9 on: October 29, 2010, 08:38:37 PM »
There's a thread on the end of the gear stick so you have to hold the gear stick while turning the knob (if it's really tight then try to hold the gear stick with pliers and a cloth so you don't scratch it and then try to turn the knob off.) My old gear knob was that universal 'touring car' style (spherical with small dents in it) and the old aircooled sphere shaped and the new longer types are interchangable.
Draigflag
« Reply #10 on: October 30, 2010, 01:20:25 AM »
Thank you, i will try it  [-/
Draigflag
« Reply #11 on: January 04, 2011, 08:59:37 PM »
Few more questions, when i replace my leaking drive shaft boot, i will probably need to top up the gearbox oil. Where is the filler hole? Is it a horizontal placed one that you stop filling when it spills and what kind of oil should I use?
Thanks   [-/
