Since sticking the voltgauge in the Niki I've noted a couple of strange occurrences:
- When the engine is cold, I'll be lucky to get more than 11.5V indicated even though the no charge idiot light is out.
- Once the engine seems to warm up it will instantly jump to about 13.8-ish volts and pretty much hold there, though I did note today it dropped to about 12.3V for 5 minutes then went straight back to 13.8V
I'm wondering whether the volt meter may be a bit dodgy (as it came from the wreck) and I'm putting a new VDO unit to cross check.
If the similar symptoms appear, does anyone have suggestions where I should start looking? I was thinking maybe it was the regulator, but when ever I've had a regulator go on previous cars it's always been over voltage.
This alternator appears to be the orginal unit, so it's 20 years old now and just clocked over 75,000 km today.
