Author Topic: Fiat 500 head on 650 cc engine  (Read 3516 times)
Jota69
« on: July 31, 2010, 10:56:51 PM »
I have an engine out of a 500f laying around in my garage and I was thinking about using the cylinder head out of that engine to modify it with bigger valves and open the intake and exhaust ports.
So my question is if I would be able to install the cylinder head out of a 500cc engine on my 650cc with no problems?
smallcox
Re: Fiat 500 head on 650 cc engine
« Reply #1 on: August 01, 2010, 10:15:44 AM »
Hi Jota,
Rusty's your man for this one and had a good thread going (check tuning section). I understand that the head will physically fit but your compression ratio will be through the roof so some work in lowering it will be required. Not sure about the qualitiy of that particular head but there's plenty of help on here [-/
Smallcox.
« Reply #2 on: August 01, 2010, 05:45:48 PM »
Do not tell Pete but I have had my vernier callipers out  ::)
Now when I did my cylinder head job we discovered that the standard 500 head has a combustion chamber which is 73.5 mms across at the widest point being non symetrical. THe cylinder bore is only 67.4 so you have got this odd 3mm per side overhang at the top of the cylinder on the 499 ccs engine. "Mr Cylinder Head" said that it would be a good idea to relieve the sharpe corner at the top of the bore localy as it could be a hot spot & not so good for gas flow.
So the bore on the 594 ccs engine is 73.5 mms so a very nice match there then 77 mms on the 652 ccs so you might be looking to taking care of a few edges on the head in this case. I have not measured any combustion chamber volumes but while a 500 head on a 652 will raise compressiion I do not believe it would be excessive. There are guys out there running 652 engines  skimmed to the point that the gas grooves have gone (about 4mms) plus no head gasket. Saw a 500 guy on a forum recently that discovered that the noise from his engine was the valves hitting the pistons. (be warned Darrell he was in SA)
My plan was to let the engine breath a whole lot better which seems to work very well . If you do increase the compression then the pistons have to overcome that force before you get the power stroke. [-/
« Reply #3 on: August 01, 2010, 05:57:52 PM »
Like the old engineer boy I hung around with in my youth used to say...
All good women need to do this more : suck, squeeze bang and blow :oops:
Sounds like a bit too much head skimming there by that boy :oops:
Fortunately I'm not the sort to trial the untested and would only skim according to a tried and tested formula [-/
Would be interested to hear there the hot spot is said to form as that makes sense to eliminate that, even on a standard engine as I don't care how much your standard engine does not overheat on an air cooled...you're still burning oil in the engine unless like Steve you have an oil cooler.
smallcox
« Reply #4 on: August 01, 2010, 06:28:45 PM »
Hot spots in cyclinder heads normally form on sharp corners (burrs) or places where heat will not conduct quickly enough. I dont beleive this to be a problem on your heads unless you fan explodes (no jib meant rusty). I think rusty meant de-shrouding the sides next to the valves to relief the gasses entring and exiting the head [-/
Alfons1972
  • sorry for my bad english...
« Reply #5 on: August 03, 2010, 10:12:48 AM »
in germany some of our friends have 500ccm heads on 650ccm-engines. Without problems.
It increases compression ratio, that's the main advantage. And therefore there will be more power, especially at low speed.
optimizing the valves and the seats will help additionally, of course...
Fiat 500 R
Fiat 500 giardiniera
smallcox
« Reply #6 on: August 29, 2010, 11:53:53 AM »
Hi again,
   Just done a bit off calculating and if the original head from a 500 runs at 7.5:1 and you then bolt it straight on a 650 engine then this will raise the static compression ratio to 9.8:1. suck, squeeze, bang then followed by pinking I would think on 95 octane :cry:
Smallcox (cup of tea time) [-/
« Reply #7 on: November 13, 2010, 12:00:47 AM »
I dunno after my electronic ignition dilemas with pinking I somehow think the extra compression might not do it :P
As I said before the ignition was advancing further than I could gauge  :o somehow the engine ran :P
« Reply #8 on: November 13, 2010, 05:17:02 PM »
OK you have rattled my cage again with this one. There were a couple of things I wanted to look at so I dug out my old 499ccs cylinder head then laid the solid copper gaskets I had made onto the gasket face to see how they match up with the combustion chambers. One gasket is standard 652ccs size & the other one is 795ccs. In the picture you can see the silver area between the cylinder bore and the edge of the combustion chamber. This area would be an unwanted step in the combustion chamber . So if Smallcox is correct about the compression ratio being a tad too high even with an unskimmed head then a little bit of work to smooth out that step for better gas flow and to remove potential hot spots woiuld at the same time give a lower than the 9.8:1 max compression ratio. Just one thing before you guys rush out to fit 499ccs heads, the inlet carb studs are the same as the 594ccs & 652ccs but the inlet throat diameter is 26mms diameter as opposed to 30mms  [-/
