Author Topic: WOT IS IT  (Read 5959 times)
WOT IS IT
« on: July 31, 2010, 07:24:20 PM »
 ??? What does this bit do , seems like some sort of resistor that fits at the top of the front panel on the later 126s  ???
Re: WOT IS IT
« Reply #1 on: July 31, 2010, 08:00:39 PM »
I've seen that one on my old BIS. Think it's something to do with the lights.
Re: WOT IS IT
« Reply #2 on: July 31, 2010, 08:17:46 PM »
thats the ballast resistor, it's wired in line with the coil.
Once warmed up its supposed to prevent the coil from drawing too much current and reducing its lifespan.
Allan
Re: WOT IS IT
« Reply #3 on: July 31, 2010, 09:25:30 PM »
If it is the part I think it is it reduces current to the low beam on the head lights so the low beam filliments are used for park lights. Pretty sure it is not a ballast resister.
Allan
Re: WOT IS IT
« Reply #4 on: August 01, 2010, 12:50:20 AM »
try unplugging it and see if your car still starts
smallcox
Re: WOT IS IT
« Reply #5 on: August 01, 2010, 10:04:13 AM »
Don't own a Bis myself but noticed it is only fitted to the Bis and its got heavy duty cable to it, just another guess but does it control the cooling fan to give it two speeds ie, low speed runs all the time and when thermostat demands (engine hot) runs at full speed?
maybe the flux capacitor :P :P :P :P
« Last Edit: August 01, 2010, 05:46:32 PM by smallcox »
Re: WOT IS IT
« Reply #6 on: August 01, 2010, 10:19:45 AM »
I'm not trying to guess, it is a ballast resistor!
I don't think they were fitted until the wasted spark coils were introduced which s why they're only fitted to later 126's
Re: WOT IS IT
« Reply #7 on: August 01, 2010, 04:54:12 PM »
it is a ballast resistor they were fitted on the bis and late fsm aircooled.
smallcox
Re: WOT IS IT
« Reply #8 on: August 01, 2010, 04:57:10 PM »
  you sure it's not a temperature sensor for the climate control :D
Re: WOT IS IT
« Reply #9 on: August 01, 2010, 05:07:30 PM »
  >:( Damn , I thought that it was a flux capacitor , that is why I put my smurf glove on to handle the radio activity  :oops:
Re: WOT IS IT
« Reply #10 on: August 01, 2010, 05:10:12 PM »
Eurika! It's the heating element that makes the BIS boil! :P
smallcox
Re: WOT IS IT
« Reply #11 on: August 01, 2010, 05:49:36 PM »
look here gentlemen and rusty, Fiat know there cars break down so fitted this, which is a heater to heat up the tool kit so you don't get cold hands when you break down at the side off the road and have to "Fix It Again Tony" :P
Allan
Re: WOT IS IT
« Reply #12 on: August 02, 2010, 01:59:34 AM »
I come back to my origional thought that it reduces the current to the low beam of the headlights when the key is turned on and the park position is selected. With the key off the standard park light bulb comes into play.
Does anyone one to start a guess the part for 126?
Allan
Re: WOT IS IT
« Reply #13 on: August 02, 2010, 11:41:15 AM »
It is a sort of Ballast resitor, but it is not the sort fitted in line with the coil. These were fitted in the front of the car and were used to reduce the current to the lights.
I have previously wired this type of resistor to my coil and it does work fine, however it is not the type designed to deal with the heat of the engine bay etc. The correct type for this is the ceramic jacketed smaller type, like this
http://cgi.ebay.co.uk/NEW-BALLAST-RESISTOR-Spitfire-Stag-GT6-TR5-TR6-etc-/120599119165?cmd=ViewItem&pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item1c1444853d#ht_500wt_1038
Re: WOT IS IT
« Reply #14 on: August 02, 2010, 11:44:50 AM »
Dom, how did you get that pic of your 500 with the front wheel in the air?
I've been told by friends who have tried following me in my 126 that is lifts a front wheel in a hard turn :oops:
